As financial firms are required to state: "past performance is not indicative of future results".
This time the situation may be different and your changes have not solved the problem.
Try some of the suggestions and tests given here.
2001 s60 !---Totally Stumped on Engine Misfire
- Has thanked: 987 times
- Been thanked: 1075 times
OliPhant
- Year and Model: 2007 V70 2.5
- Has thanked: 3 times
- Been thanked: 11 times
'07 V70 I had misfire turned out to be a combination of 1 bad injector and a coil failing intermittently. Replaced the injector and all coils - running good for now.
Yep. The misfire algorithm works well for a constant miss, but ot can misread the cylinder if it’s rough running or an occasional miss, in my experiencevtl wrote: 28 Jan 2026, 14:18When my #1 blew, I had misfires detected in two cylinders. Forgot which ones, but #1 was not among them.yabadabadoo1026 wrote: 28 Jan 2026, 14:15 im no certified mechanic but wouldnt seem to me that would entered into misfire???????--------and why would i check any cylinder other than the one the code is suggesting????? Thanks
You want all cylinders compression tested.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
This was with 0 PSI in #1... Misfire counters were like #2 and #4. Contrary, a dying fuel injector in #3 that was missing the mark sporadically, but it was correctly diagnosed by ECU. Maybe with #1 it goes south because it is the first cylinder in firing order.abscate wrote: 08 Mar 2026, 01:41 Yep. The misfire algorithm works well for a constant miss, but ot can misread the cylinder if it’s rough running or an occasional miss, in my experience
- 2801 Views
Last post by famfeld
- 1032 Views
Last post by TisMe
- 661 Views
Last post by Krons
- 1221 Views
Last post by dgcantrellsr
- 691 Views
Last post by dikidera
