V70 2002 - power steering fluid filter?
Has thanked: 2200 times
Been thanked: 1852 times
Or try to lubricate it at least to see if it is partially seized. This is often missed as a steering issue.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
scot850 wrote: 07 May 2026, 08:32 Or try to lubricate it at least to see if it is partially seized. This is often missed as a steering issue.
The corrosion and friction actually happen under the U-joint caps, you can't lubricate that. And greasing U-joints externally is generally no go, since it only attracts dirt.
I was suggesting it only to try to identify the cause of the issue. If it is the issue then replace it. Ig not, clean off the penetrating oil excess.
vtl
Post by vtl »
scot850 wrote: 08 May 2026, 08:20 I was suggesting it only to try to identify the cause of the issue. If it is the issue then replace it. Ig not, clean off the penetrating oil excess.
It is fairly easy to test it directly. Go under the dash, disconnect the shaft (one bolt), remove the boot and here you go: you can twist it in any direction and check U-joint.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
I am very lazy and have sprayed PB Blaster from afar to shut mine up in the past prior to replacement.
I remember someone mentioning to baste it in grease and use a torch to melt it into the joint :lol:
04s60 2.4
04xc70 2.5t
MotorTheresa
Year and Model: V70 1998 B5252F/S MT
Has thanked: 33 times
Been thanked: 15 times
Post by MotorTheresa »
Negative, we did not touch the intermediate shaft.
But thanks for the suggestion! We will consider the disconnect from steering column approach to test it's overall friction in any accessible axis.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
MotorTheresa wrote: 10 May 2026, 09:13 Negative, we did not touch the intermediate shaft.
This is a very good suggestion. I had funny feeling steering in my Titanium grey 2007 S60 and found that the universal joint is stuck in one direction. Then the bolt holding it clamped to the steering rack snapped when I was trying to loosen it. Then after I cut the old part off the rack by hand and with a reciprocating saw, I found that I had the wrong version of the replacement part. The early cars have a different interface to the steering rack compared to the 2005+ P2 cars.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
br0dy519
Post by br0dy519 »
Yes there was a change in 2004 regarding the shaft. One is slightly smaller than the other. Measure the length to ensure you select the correct one when you order it.
04s60 2.4
04xc70 2.5t
