OBDII code P0102
Geevs
Has thanked: 9 times
Been thanked: 2 times
Post by Geevs »
Hi Tsquared,
Could you kindly post instructions on how you cleaned your MAF sensor?
I also used a K&N panel filter but have gone back to stock paper due to my concern about the K&N oil getting on the MAF wires and thereby affecting it's performance.
Thanks,
Geevs
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
scantool.net looks like the software is free, and they sell the connection hardware... is that what you get from the site Geevs?
If so, I'll try it out, since I have the hardware.
Also -> Amazon link
Guest
Post by Guest »
Hi Matt,
I don't have any OBD-II scantool yet but have been searching the Net for one.
Yes, I suggested you try the free and evaluation software from the sites above with your existing OBD-II interface and see if it works. The software from the obd-2.com website looks horrendous. The Digimoto looks very user-friendly. The German one from wgsoft.de looks nice, too, but is in German. I am basing my impressions from the screenshots on their websites.
Let us know how it goes.
Geevs
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
This is from memory tainted by quite a few glasses of red wine...
I disconnected the intake to airbox hose. Disconnected the MAF connector plug wire. Used my Dremel to smooth the sides of the non-tamper screws so a 3/8 open end would work on them. Removed the sensor. I then used an acid brush and 99.9% isopropyl alcohol to clean up the sensor and the waffle grill. I then used a low-pressure air hose (20 lb) to blow off the excess fluid. Let them dry out fully (cleaned K&N filter and re-oiled) and reinstalled. While I had all of this apart I also cleaned my flame trap, flame trap elbow hose, and all the parts of the intake up to the intake manifold itself.
Alcohol works wonders and the effects are not that bad. And it can also be used to clean up your intake
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
