seafoam question
mrreilly
- Year and Model: 1998 Volvo S70 GLT
Well, after a few days, I really haven't seen a very big improvement after the seafoam treatment. i have noticed a little smother idle and a slightly smoother acceleration. Other than that everything still seems like it was before. I drove it for a good 3-4 hours yesterday, and this car sure doesn't have the same response as it used to...
1998 Volvo S70 GLT Black/Tan
Approx. 173,000 3/27/2010
My major repairs:
Timing Belt, Left&Right Control Arms, Tie-rod ends, Lower Engine Mount, Engine Stabilizer Mount, IPD Sway Bar Links, Brakes , Head Gasket, PCV System, Turbo Rebuild, and more
My major repairs:
- volvoaddict007
- Year and Model: 760 Turbo
Hi mrreilly,mrreilly wrote:Well, after a few days, I really haven't seen a very big improvement after the seafoam treatment. i have noticed a little smother idle and a slightly smoother acceleration. Other than that everything still seems like it was before. I drove it for a good 3-4 hours yesterday, and this car sure doesn't have the same response as it used to...
I'm a bit confused on your post. Are you saying that for a few days it seemed about the same and then yesterday something changed and the response ( acceleration ? ) is less ?
Thanks in advance for clarification.
Still curious on any members thoughts on this or if they have tried it. Instead of introducing the seafoam at the vacuum tree it is applied to one of the hoses running into the oil seperator? Or does entering at the vacuum tree cause the material to run through the seperator all the same?Seems like it could be a way of cleaning out the oil seperator ( under the intake manifold ) and lines periodically.
volvo ( anti-spamfilter )
1990 5 speed 760 Turbo Wagon 310K.
( '91 940 turbo eng. + trans.)
Konis, diesel springs, 2.5" exhst., 850 T5 wheels
1993 300ZX 2+2, 171K
1999 Ford Windstar LX, 90K
I tried Seafoam today. I put in about 3-4 ounces through the vacuum tree and waited about 20 minutes. When I first started it back up it smoked sa pretty good bit and then as it sat there at idle, it quit. Then I took it for a short(about 15 minute) drive. For a little while each time I got on it, it would smoke pretty badly. Then it quit smoking and ran smooth and seemed to have a little more power.
The CEL came on almost immediately after I restarted it. I haven't checked it yet to see what kind of code I have.
Larry
Li'l Red Wagon
97 855 GLT
Li'l Red Wagon
97 855 GLT
- Has thanked: 17 times
- Been thanked: 35 times
Probably an 02 sensor from all the smoke. Clear it and you should be good to go! Let us know how the long-term effects of this are. So far, my conclusion is that any improvements are short lived, but hey, what do I know.
Will do...watching the Colt right now...go Peyton!
Faheyk1981
- Year and Model: Volvo V70 1999
Hi,
Would anyone know where i could buy Seafoam online that delivers to Europe? (Ireland)
I've been looking all over the net and cant find anywhere that will post outside the US.
Kind regards,
Kevin.
Kind regards,
Kevin.
- kcodyjr
- Been thanked: 23 times
I'm surprised if they'll post at all, even within the US. Even nail polish remover is a controlled substance now.
That said, pick a major vendor and give them a call. They may want you to buy a few bottles to offset the cost of int'l hazmat shipping.
5 others that came and went
- 601 Views
Last post by Ozark Lee
- 11 Replies
- 2831 Views
Last post by MarcM
- 2122 Views
Last post by mecheng
- 1019 Views
- 39 Replies
- 6057 Views
Last post by DanelleNavarro
