Squeaky dash - solution
This topic is in the MVS Volvo Repair Database » Squeaky dash - solution
dukedms
Year and Model: V 70 GLT 1999
Post by dukedms »
I believe that one of my plastic tabs is broken. I gently tightened down the four bolt and the bolt farthest to the passenger side turned easily and that's where the squeek is located. How do I replace that one plastic tab?
Thanks,
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
dukedms wrote:I believe that one of my plastic tabs is broken. I gently tightened down the four bolt and the bolt farthest to the passenger side turned easily and that's where the squeek is located. How do I replace that one plastic tab?
Thanks,
Unfortunately the whole dash needs to come out to get to any of the mounts and make a proper repair. Keep track of the pieces if you decide to go that route. Once the dash is out it is an epoxy and reinforcement method. Others have tried fiberglass patches to hold thing back together but I don't really know the success rate.
Volvo4251
Year and Model: 98 S90
Post by Volvo4251 »
I've seemed to notice all 850's have their own dash issues. Mine isn't really squeaky per say, but I wonder if this symptom is worth anything of note- a few of the torx screws around the inner door frame (open the glove box door they are the screws [six total] that connect the actual "box" to the dash) have separated from their original holes. I guess this must be happening from the actual dash moving around, even slightly, over time. Would this be a sign of loose bolts under the cowl or broken dash tabs? Again I'd have to say my dash isn't really that noisy, maybe over a pretty rough road- and there are plenty in Chicago-but otherwise it doesn't make any alarmingly loud noises. Just curious! Thanks
Drive Safely.
2007 Volvo XC70 Adventure Series
1998 Volvo S90
Previous Volvos:
96 Volvo 850 Platinum
11 Volvo C30 T5
07 Volvo XC90 3.2 AWD
98 Volvo V70 2.5 SE
95 Volvo 850 Turbo
94 Volvo 850
91 Volvo 240 Wagon
90 Volvo 240
89 Volvo 740 GL
Ben850
Been thanked: 7 times
Post by Ben850 »
Volvo4251 wrote:I've seemed to notice all 850's have their own dash issues. Mine isn't really squeaky per say, but I wonder if this symptom is worth anything of note- a few of the torx screws around the inner door frame (open the glove box door they are the screws [six total] that connect the actual "box" to the dash) have separated from their original holes. I guess this must be happening from the actual dash moving around, even slightly, over time. Would this be a sign of loose bolts under the cowl or broken dash tabs? Again I'd have to say my dash isn't really that noisy, maybe over a pretty rough road- and there are plenty in Chicago-but otherwise it doesn't make any alarmingly loud noises. Just curious! Thanks
Just last week I replaced the dash pad with one from a parts yard car. The original owner must have took great care of this dash. It felt like it still had armor all, or some other protectant still on it. Anyway, I made sure when reinstalling the dash pad to physically hold the dash together tightly while replacing screws. As opposed to letting the screws pull the gaps together. I found this served to line the fitment better as well as to not stress the fastening points and possibly make for a loose fit (squeaky) later. The dash is pretty quiet for now.
I've probably had the glove box out a dozen times now for various reasons. At this point I don't think any of the screws are actually holding the box to the frame itself anymore, but more or less keeping it positioned. The plastic under the screws is pretty much gone. Though I don't believe it is the cause of any of the other noises I was hearing. I have three glove boxes I've brought home from the yards, and they are all like that to some extent.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
Until I can get in there and fix my dash with some bolts, washers and loc-tite, I just used a tie-down to stop all the annoying squeaking.
I'll post pics of what I did tonight.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
MCV in WV
Year and Model: S70 2000
Post by MCV in WV »
Ugh. I tightened mine a bit because there was lots of noise from the dash. Three were fine but when I tried the one furthest to the passenger side the bolt broke! How much trouble am I in now?
jb24601
Year and Model: '98 S70 GLT
Post by jb24601 »
Rubber vacuum hose between steering column and dash. Loosen column adjust, insert tube, push up on steering wheel , lock. Thanks to a poster on Volvospeed for this one. Working for my S70 which clearly had driver side mounts broken but other side ok. Tried this thread's tightening of four bolts under wiper cowl. No change. You can't make stupid design flaws go away, but this trick may work for you until you decide another course of action.
