Trouble starting 850, need suggestions Topic is solved
potroast
Post by potroast »
push down on it while cranking the engine. You should feel the relay kicking on.
Guest
Post by Guest »
ok I'll give it a try by the way the fuel pump controller on my ride is pink colored and labled so. If the fuel pump controller is bad would the egine still crank to a start?
potroast
Post by potroast »
yes
petershen1984
Post by petershen1984 »
DCintraining wrote:If it's not plugs or electrical, then it is probably fuel. The only other thing that comes to mind is that you are losing fuel pressure when the car is turned off. If air is introduced to the system then the fuel pump would have to work for a few seconds (or more) to get the pressure back up to the fuel injectors. Anyone have any ideas on how to (safely) test this? Have you pulled the codes off the computer? Here's the site to tell you how:
http://au.geocities.com/ozbrick850/comp ... volvo.html
Thanks to Matt for this great Volvo owner's site.
Eoin
Ahh, now I know why it's harder to start after playing with the throttle pedal with the car turned off (1988 740), what I'm doing is introducing air into the system! But my 740 has the same problem still unresolved.. I think it may be a stuck check-valve -- it's supposed to maintain some pressure in the system so the fuel doesn't flow back into the tank, thus requiring the pump to work the full distance again...
Off topic--
I just never wanted to leave my car with the mechanics overnight. Just now my sister called and complained about the lack of air conditioning. This would be the third time I've had to refill since undergoing the retrofit R134a procedure last November, this coming from an authorized Volvo service shop!
Peter Shen
1992 Volvo 960 (Silver)
Guest
Post by Guest »
I replaced the fuel pressure regulator and it starts like a champ!
petershen1984
Oh yeah, my issue above was resolved when they readjusted my idle speed.... but now I need a new battery - I had it run down too many times.
Peter Shen
potroast
Post by potroast »
Get an Exide Orbital or Optima Red-Top... They cost a little more than the average battery, but its the best battery you can get 8)
96850
Post by 96850 »
96 850
Ok I tested the fuel controller relay-it works fine-now what? I still have internittant 6-8 seconds churning before the engine cranks. Seems to be an issue after engine is heated. Is fuel pump the culprit?
Any uggestions welcomed.
potroast
Post by potroast »
as matthew suggested earlier, check that you have fuel pressure by unscrewing the cap on the right side of the fuel rail, and depressing the schrader valve. If fuel spritzs out, then your fuel pump is okay.
Guest
Post by Guest »
You said-
Is the fuel rail run along the valve cover? I cannot locate the valve you refer to.
