Ah!
My car does that occasionally after I restart from a brief stop (doing errands). Would certainly like to know why/cure...
Replacing Climate Control Unit
I have an '05 XC70 which I bought with 111K on it. The climate control was wonky in that the driver's side temp control wouldn't vary the temp. All cold until knob set to highest (red) setting. I've replaced and tested 4 other modules from a junk yard. Various results but none a full functioning module. I've seen bits and pieces of advice about how to correct the problem, including sending the module off to be "reset", resetting using an OBDII tool, etc. I've not found a comprehensive discussion of diagnosis and repair/replacement of the CCM on this site. Any experts out there willing to dialogue with me?
- Has thanked: 1611 times
- Been thanked: 4072 times
You need a VIDA setup to diagnose the CANBUS cars - you can't do it from current flow diagrams like the old days.
I am also not sure you can swap modules in without marrying them to the CANBUS correctly, so part swapping might be futile (like resistance)
- 11 Replies
- 6837 Views
Last post by maxi948
- 3924 Views
- 2561 Views
Last post by nsomlai
- 2483 Views
Last post by DrDan
- 553 Views
Last post by 1999V70XCinPA
