Thanks! SO if I get these SMD boards w/the wires...Then what would be the things I would do next for installing them for the front dome reading lamps? I'm not the greatest when it comes to electrical work, as I rarely do it.Red-Arrow wrote:Actually the lights are specifically or actual white, the SMD's I believe emit a colour of around 5000K or Kelvin which is the colour of a cold white tube light. Warm white would be 3800K or 4000K. The cameras white balance is off at night which determines how the colour in the pictures looks so I can assure you its not blue at all.
Interior LED lights upgrade with pictures.
Project: Volvo Interior LED Lights Upgrade DIY Tutorial
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Do you know if this polarity issue is likely the same in later models i.e. 2000?
I'm really interested in this mod and hope to do it ASAP! I just ordered one of these as a test:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
It comes with adapters, so that should make life easier!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
viper69
Let me know how this goes..I'm very interested too!ecbsykes wrote:Do you know if this polarity issue is likely the same in later models i.e. 2000?
Volvo 850 GLT 1995
FlyingVolvo
Will do! I probably won't have any results until after January 10th, as I'll be in Alaska... but I'll be sure to post back here.
If the adapters work as they seem like they do, I'll be ordering a bunch of them.
2023 V60 T8 PE
2023 V60 T8 PE
Red-Arrow
- Year and Model: 850 T5 1995
The polarity problem is Volvo being smart and saving on wiring so I guess all the Volvo's should have the same issue. Just buy the SMD boards so you can flip the polarity at will.
Life would be enjoyable if it wasn't so painful to live.
viper69
The ebay link posted above I take it is the correct SMD board to buy. I looked at the web page and it comes with a few adapters I think. I'm just guessing, but I assume I would use the board connected to the "bulb" like looking piece that is right next to the board in the picture. Then I can flip the "bulb" adapter for the correct polarity right?Red-Arrow wrote:The polarity problem is Volvo being smart and saving on wiring so I guess all the Volvo's should have the same issue. Just buy the SMD boards so you can flip the polarity at will.
Second, how will the board mount inside the driver side and passenger side map lights up front in an 1995 850? (I assuming that's where they fit, I don't know if the boards in the ebay link will fit into the doors on the side, AND fit into the reading lights for the passengers in the back. Anyone know?
Volvo 850 GLT 1995
outdoor7or24
- Year and Model: SOLD 95 855t,93 945t
Is the map light (the light over the console area) to bright at night? Just wondering as to go from darkness to bright light when you are trying to read a map or something...
Any issues Red-Arrow?
ojdorson
- Year and Model: 850R, 1996
- Been thanked: 3 times
I did this a few months ago and it's great! The car just seems much more modern with this color lighting, and it's brighter without being glaring.
I'll second the suggestion for SMD boards as the bulbs end up with and SMD shining UP into the roof, and what good is that!
I'm probably going to redo mine with boards when I do my headliner (thanks for the other write-up!). I'm thinking of just taking my headliner out and having it done with charcoal alcantara at a local interior place.
viper69
The ebay link posted above I take it is the correct SMD board to buy. I looked at the web page and it comes with a few adapters I think. I'm just guessing, but I assume I would use the board connected to the "bulb" like looking piece that is right next to the board in the picture. Then I can flip the "bulb" adapter for the correct polarity right?viper69 wrote:Red-Arrow wrote:The polarity problem is Volvo being smart and saving on wiring so I guess all the Volvo's should have the same issue. Just buy the SMD boards so you can flip the polarity at will.
Second, how will the board mount inside the driver side and passenger side map lights up front in an 1995 850? (I assuming that's where they fit, I don't know if the boards in the ebay link will fit into the doors on the side, AND fit into the reading lights for the passengers in the back. Anyone know?[/quote]
Would some of you guys be able to answer the questions?
Thanks in advance.
Volvo 850 GLT 1995
- 11 Replies
- 15937 Views
Last post by DavidArman174
- 1158 Views
Last post by larrico
- 1090 Views
Last post by Rattnalle
- 647 Views
Last post by darrylrobert
- 1430 Views
Last post by Abrown99
