Is the Vishay sensor easy to source or do they put you through the griller to buy one?
Also may I ask approximately what the cost of the sensor was?
Volvo s60 P/N 8644345 2001 non-turbo ETM pictures
precopster
- Year and Model: Lots
- Been thanked: 128 times
Looks like you can buy single for about $35 US. Shipping from this site to Australia is like $20+precopster wrote:Is the Vishay sensor easy to source or do they put you through the griller to buy one?
http://www.mouser.com/ProductDetail/Vis ... YUEM4L0%3d
Job requires cutting open the Vishay and lots of custom precision assembly to set proper alignments + spaces + voltages. I'd say not for DIYer who prefer plug and play. Sacer TPS seems to be exclusive to Xemodex in US so not available to US consumers.
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
Hi Yehuda,
I'm reading with interest you topic from the time you started it. Nice job, man!
So my question is: a year later how is the sacer's sensor behave? Any problems at all? Idle, cruise, DTC codes ...
I'm planning to go over your steps, but sacer's worker told me the minimum order s for 5pcs - however, i'll find 4 friends here in BG to combine the order. I just need to be sure that the TPS is reliable.
Thanks for your response.
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
Yehuda
- Year and Model: S60 non-turbo, 2001
- Been thanked: 3 times
Hello yuckuJackD,
the sacer's sensor works great as it should, i haven't faced any problems related to it, it's very reliable from my experience.
BTW, if you can't find more friends to combine the order & you need it fast, i'm selling them on eBay.
here are links to the listings:
Auction: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... RK:MESE:IT
Fixed price: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... RK:MESE:IT
Good Luck,
Yehuda
Good Luck,
Yehuda
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
Just ordered a eBay saucer TPS lets see if I can make this work
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
yuckuJackD
I'm in process of waiting stock amounts in Sacer's shop, and buying 5 units. 2 for me and 3 for a friend.
I'll tell the results after that
Many thanks to Yehuda, for sharing his experience with us!!!
yuckuJackD
The sensors are in my hands. Hip-hip-Oleeeee
Tonight is THE night
precopster
Good luck. Be sure to cut down the shaft sufficiently. Also use an earthed soldering iron as the boards are very susceptible to static damage. When hacking out the putty use a pick tool for speed.
Use the casing to lever the three sensor prongs apart as heat has almost no effect. With the disconnected 5 prong side you can drill it apart with a 2mm drill bit and then dremmel the rest. Avoid using heat unless you're soldering and if so make it very short bursts and allow to cool between solderings.
If your solder has no flux get some resin based flux in a tub (made by Kester) and use this to help the joint flow.
If you end up with codes allow 3 cycles for them to clear.
Hope this helps.
Sent using Tapatalk 2
Hope this helps.
yuckuJackD
Thanks for guidance, but I read it too late I guess...
I've done everithing as it should except two things (both are possibilities of overheating):
1. While splitting the pins first i tried to desolder them. At begining at 250 deg, then 300 and at the end I hit tha max - 450deg. When I realised that heating doesn't help at all I cut 1-2 mm from top and they were all free, but before that I've been applying alot of heat trying to desolder them. - Could this heat process caused any damage to the electronics inside the body?
2. I soldier the new sensor without being careful of overheating. 300deg for 5-10 sec for a pin and no time for cooling between pins. Again - Could this heat process caused any damage to the new sensor?
What I'm tring to find out is what whent wrong - the body itself or the sensor.
Symptoms:
limp home (mine is wrote in French, so I'm not sure the exact message in English)
When I connect the car with DiCE and VIDA I got general Throtle error + errors for both 1-st and 2-nd sensors.
Live data shows i got no measurment at all. Both are dead on 26-28%.
Tonight when i get home i'll post pics from the whole process so that it be clear what and how I did (nothing different than others in fact but ... who knows).
Thanks for ANY support.
Symptoms:
yuckuJackD
At this moment I thought i need to desolder the pins. Applied alot of heat but with no sucsess. Then I just cut 1-2mm from top and the pins were free from each other.
Is this shorten enough?
I'm afraid that at this point maybe i've overheated a bit the pins.
Link to the whole album with possibilities for bigger/better images: click
Latter I could post some screenshots from VIDA with the car connected.
- 4502 Views
Last post by ajwsurfer
- 4959 Views
Last post by antonevane
- 15 Replies
- 6761 Views
- 4717 Views
Last post by firstv70volvo
- 15 Replies
- 3494 Views
