Sunroof Won't Open After Battery Was Disconnected??
Disconnected Battery, Now Sunroof Won't Open
brandonbeach14
- Year and Model: 2.4T V70, 2001
How long in between each step? The last time I tried it I disconnected the battery, touched the wires together, waited a few minutes, reconnected the positive last. I am assuming that I lock the door after reconnecting the battery, waited a minute, and then did the remaining steps. Thanks again.
brandonbeach14
Gotcha, I have received several different ideas on how to fix this. The odd thing is the siren hasn't worked for at least a few months when I bought the car, but the sunroof did. I disconnected the battery to remove the positive terminal in the engine bay by the fuse box to get to the O2 sensor connection that started all of this.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The current draw to keep the siren battery charged may have been low enough that things were JUST barely ok. Battery disconnect may have been the little pus it took for the siren to be finished.
brandonbeach14
Update....The sunroof is now opening and closing again after 6 weeks of not working. Absolutely crazy. The alarm horn is still not working. I am going to leave it closed just in case the car chnages it's mind.
For what it is worth, when my '01 S60T sunroof refused to open it was the clue that the alarm siren module was bad. Changing it cured the sunroof problem. See the writeup in the S80 section for the procedure.
And I have had my battery disconnected numerous times, all probably less than 2 hours with no problems generated.
I always undo the negative cable only.
Also see my post on failed horn. Is this a alarm module symptom? Horn itself is OK.
Did you end up figuring this out? After reading this post you had similar problems as I am having. Does anyone know how to change the alarm battery?
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
brandonbeach14
brandonbeach14
It actually started working on it's own. The sunroof is on the same circuit as the alarm siren. We had heavy rain earlier in the month and I guess that water got into the box and completed the circuit. It's still working, but I am leaving it closed. I was able to find a new siren for $100-150, but haven't bothered with it yet.
- 812 Views
Last post by beigg
- 25 Replies
- 13654 Views
Last post by wizechatmgr
- 713 Views
Last post by twiggs462
- 1134 Views
Last post by racertim
- 1811 Views
Last post by IslandV70
