It is possible if the seal does not get seated properly or the old seal breaks up when re-fitting and blocks the abs sensor reading correctly. The sensor reads the grooves in the toothed wheel. If a piece gets in there or there is a build up of crud gets dislodged into the 'teeth' it will throw a wobbly.
I would fit new seals and carefully make sure all the rust is cleared out of the teeth with wire brushing before fitting the new seals.
Rubber Dust Shield between the axle shaft and hub bearing?
Kick Panel Broken Tabs Fix
- Has thanked: 1848 times
- Been thanked: 1710 times
Re: Rubber Dust Shield between the axle shaft and hub bearing?
ronmeneses
- Year and Model: 2005 V70
Yeah, thanks. I was expecting that would have to be my next step. Not looking forward to repeating the work, haha.
I hear you. I have the RH axle seal to do on our son's 06 XC70. Really looking forward to that............!
