1995 850 Starts, runs 1 sec, then dies
Ben850
Been thanked: 7 times
Post by Ben850 »
a73s wrote:
beigg wrote: CTS functioning to spec?
Thanks beigg,
What is CTS? (Sorry, just new to a lot of this, and trying to save some cash on the repairs!)
Alan.
CTS Coolant Temp Sensor.
MAF sensor would be a good item to swap, maybe with a salvage or known to work item.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
a73s
Year and Model: 850T 1995
Post by a73s »
Well, I unplugged the MAF and the car did the same thing..started then died about 10 -15 secs later. I opened the air box and sprayed some MAF sensor cleaner in to the pipe with the MAF sensor, and I used an electrical contact cleaner on the connector.
I started the car, and it started up, and continued running for about 30 -40 sec, getting very rough and rumbly, but it eventually cut out and died. It did run longer than usual (10 -20 sec.....but it did still die on me).
Then I pulled some codes from the A-2 OBD port...and got a ton of codes including "MAF Sensor signal" "Misfire on at least one cylinder" "Misfire on Cyl 1" "... Cyl 4" "...Cyl 5". I wasn't sure about these codes because I thought they are probably reading the fact that I disconnected the MAF to test it earlier in the day, so I cleared all the codes and started the car again, it died after about 10 sec's, and I immediately tested the A2 (Fuel System) codes and there are none!
Any other suggestions really appreciated!
Thanks,
Alan.
Ben850
Post by Ben850 »
Swap MAF with known good.
Front O2 sensor after.
a73s
Post by a73s »
OK, ended up taking it in to a mechanic and he replaced MAF and everything seems to be good now (also replaced fuel filter but he didn't think it was causing the problem).
I was surprised because I thought the car should run / start with the MAF disconnected (which I tried)?
Anyway, seems to be good for now.
Thanks for all the help and suggestions.
