How do I retrieve the correct mileage on 1996 850
How did you reset your odometer?bankrum wrote: ↑07 Dec 2018, 12:21 Thanks to Mashmash and the posted tip for purchasing the BAFX bluetooth OBD reader and 850 OBD-II android app, I too have retrieved the true miles for my 1996 850 and subsequently repaired the odometer and reset it to true miles. This was a great tip.
During the odometer repair process, I found that the small plastic gear was NOT broken. Rather, it was simply "stuck" or frozen on its shaft. I replaced both gears nonetheless and it is now working like new.
Thanks again to Mashmash!
- Has thanked: 292 times
- Been thanked: 765 times
You can use a pencil with eraser hooked onto a drill e.g. Others have forced the gears to the right place but I don't recommend that.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Does VOL FCR show the odometer on a 97, I can’t
Find it listed?
Find it listed?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
OK - I've looked everywhere and this seems the best place to ask. I have replaced my odometer gears and am trying to reset the mechanical wheels to the actual mileage. I bought an EPROM reader to download the 93S56 memory contents from the instrument cluster which should contain the actual mileage info, and now have the HEX info. I thought I had heard that you could then decode the HEX and get the mileage. I understand that there are shady characters out there that could manipulate this data to their advantage, so because of that I can't find the location and how to decode this HEX dump. Is there someone or a service who can decode it for me so I can reset my odometer? I don't need to know the actual EPROM data location, I just would like to know the decoded mileage. I can send the HEX dump to you...
Thanks,
Mark
Thanks,
Mark
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 24 times
- Been thanked: 22 times
Hi Mark,Rometsch wrote: ↑26 Dec 2025, 14:21 OK - I've looked everywhere and this seems the best place to ask. I have replaced my odometer gears and am trying to reset the mechanical wheels to the actual mileage. I bought an EPROM reader to download the 93S56 memory contents from the instrument cluster which should contain the actual mileage info, and now have the HEX info. I thought I had heard that you could then decode the HEX and get the mileage. I understand that there are shady characters out there that could manipulate this data to their advantage, so because of that I can't find the location and how to decode this HEX dump. Is there someone or a service who can decode it for me so I can reset my odometer? I don't need to know the actual EPROM data location, I just would like to know the decoded mileage. I can send the HEX dump to you...
Thanks,
Mark
While I don't know if the data you got from the EPROM reader will compare to the way I got mine from the cluster, check out this old thread viewtopic.php?t=61976 . My post (4th from the top) tells you how to decode HEX (base 16) as well as which numbers to use. Good luck.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
Get a bluetooth obd2 dongle, and the obd850 app. It'll give you the mileage to the nearest 10 miles (no idea why it doesn't do the one's digit).
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1497 times
- Been thanked: 3809 times
They were a bit short of data , Shirley.
Thanks VERY MUCH for the links - I tried this and got this result...
Any ideas?
[17:07:09] ATZ > ELM327 v1.5
[17:07:18] ATL1 > Request timeout or failure
[17:07:23] ATL1 > ATL1OK
[17:07:30] ATE1 > 010041 00 80 00 00 00 41 00 BE 1D B0 00
[17:07:35] ATH1 > Request timeout or failure
[17:07:40] ATH1 > ATH1OK
[17:07:45] ATAL > ATALOK
[17:07:51] ATKW0 > 010048 6B 1F 41 00 80 00 00 00 93 48 6B 17 41 00 BE 1D B0 00 96
[17:07:59] ATTA 13 > ATTA 13OK
[17:08:09] ATII1 51 > ATII1 51
[17:08:33] ATWM 82 51 13 A1 > ATWM 82 51 13 A1OK
[17:08:42] ATSI > ATSIBUS INIT: ...OK
[17:08:54] ATSH 84 51 13 > ATSH 84 51 13OK
[17:09:01] B90300 > Request timeout or failure
- gmh
It looks like you should have repeated the B90300 command when you got the "Request timeout or failure" response as you did earlier in the string with ATL1 and ATH1. The response to that command should contain the mileage data.Rometsch wrote: ↑29 Dec 2025, 18:16 Thanks VERY MUCH for the links - I tried this and got this result...Any ideas?
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1969 145S (1987-91)
1973 145E (1989-90)
- 1204 Views
Last post by RickHaleParker
- 2871 Views
Last post by mctee
