1994 Volvo 850 T5 Correct places for vacuum hoses?
and1one1
Year and Model: Volvo 850
Post by and1one1 »
Hello
Where i should take hose to fit that tap on intake tube?
Where this upper vacuum hose belongs @ intake manifold?
this part fell of somewhere when i was taking lambda off?
Thanks for replies
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
First 2 images do not seem to be working for me.
chrillew
Year and Model: volvo 850 T-5R 1995
Been thanked: 2 times
Post by chrillew »
The last pic. that should be sitting on the Engine block heater i think.
MrGruffles
Year and Model: 850 Turbo, 1994
Post by MrGruffles »
It might help if you can tell us what the other ends of the red and blue hoses are connected to. (They look like aftermarket upgrades so color alone won't give a clue.)
I also have a '94 850 t% but unfortunately don't remember ever seeing the metal box in Pic #3.
Ian
_________________________
Current Stable:
1994 Volvo 850 Turbo Wagon (A/T, Stage 0 in process...)
1994 Mazda Miata M Edition
TBrown00
Year and Model: 1996 854 GLT
Post by TBrown00 »
I can't tell from your photos where those lines should be going, but this thread is a good place to start: https://www.matthewsvolvosite.com/forums ... php?t=6941
There will also be a vacuum diagram on the inside of your hood you can check and hopefully be able to trace the lines with.
and1one1
Post by and1one1 »
Here are better pictures. Red circled the problem spots.
The red vacuum hose isnt related. Its coming from turbo and going TCV.
Tried to read that Vacuum hose diagram but doesnt help me much for those two lines (?)
Tap on air tube needs hose
Upper hose near intake manifold
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Is there a vacuum diagram on the hood of your car?
Most of the lines on your car will be similar to S70 so the nipple on the air tube probably runs to the fuel pressure regulator (https://www.matthewsvolvosite.com/forums ... hp?t=63615).
But the 94 probably has EGR and CVVT manifold so there are some quirky lines near the vacuum tree, would help to see the vacuum hose diagram on your car.
The second one, at the vacuum tree, is there a hose connected right now and you want to know what to do with the other end, or there is no hose at all right now?
and1one1
Post by and1one1 »
Found the right places. Bypass valve hose goes to intake manifold. First picture.
Tap @ intake tube gets a hose from TCV. Second pic.
My car has no EGR i think. Its European model, 2.3 litres engine. Not Usa model
What kind of Coolant fluid i should buy, which color etc? :shock:
Post by erikv11 »
If you are in Europe you may have more options but over here I buy Zerex G-05, it is very close to what Volvo will sell you. But a lot of people even use any old green coolant with apparent issues.
