Smoke and no Coolant
boonmariachi
- Year and Model: 850 non turbo , 1996
Re: Smoke and no Coolant
Thi is turning into one big cluster f*&k. How the hell do you get this lower thermostat housing off with all this crap in the way. Just spent a hour moving the pwr steering pump that's why its a clear shot. Pleasze anyone out there help.
- 2012-01-16 22.16.26.jpg (603.58 KiB) Viewed 1043 times
precopster
- Year and Model: Lots
- Been thanked: 128 times
PCV can be done without removing the thermostat housing. In fact the cylinder head can be removed without removing this.
The lower manifold bolts only need to be loosened, not removed. Get yourself a 1/4 inch swivel and extension and you can work your way to that corner manifold bolt. Make sure you take both the bolts off the bottom of the manifold. One secures the dipstick and the other has a metal bracket attached to the block.
boonmariachi
So everything is bac together, but now the drivebelt is waking of the alternator any thoughts...is there an adjustr to move the lternator over or anything like that?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Is it fully around the crankshaft pulley at the bottom?
Release the tensioner, move the belt back on to all the pulleys, and then reset it again.
'98 S70 T5
2016 Chevy Cruze Premier
boonmariachi
yes it is
boonmariachi
i think what the problem might be is that i'm routed it unsing haynes manual for 98 and later,.....i'm an idiot ill let you know what happens!!! Oh by the way this was the old thermostat housing lower
- 2012-01-22 10.57.37.jpg (612.46 KiB) Viewed 979 times
