We have a 2000 V70 with a 5 speed AW55-50SN transmission that was built in 2000 ( I think it was July) . The B4 servo cover was bent and we had the 2-3 shift flare problem.xHeart wrote:A follow up to Fazool's post, within the chassis range, the first 3 digits of the serial number on the affected transmissions are between 01C (March 2001) and 01L (December 2001).
IPD suggests a software update (regent noted above) before replacing the B4 Servo Cover. Does this replacement remedy the design flaw you point to Fazool?
We had the software update done then had the cover replaced. The trans is not perfect but seems to be adapting after a battery cable pull.
BTW I would NOT be placing a Swepco trans oil anywhere near the AW55-50. It is not JS-3309 (or Toyota IV) specced.
It may be OK to use this in the AW50-42 which uses Dex III compatible oil.
