2002 S60 Thermostat
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Re: 2002 S60 Thermostat
Post by oragex »
It looks pretty much identical, if the rubber seal can be swapped it may work
Found this Finnish site, where a guy talks about it. Can't quite understand whether he says if it can fit it (google translation doesn't help)
http://www.vrcf.fi/foorumi/index.php?topic=6416.15
On a russian forum, there seems another guy has installed the Gates and it worked well in a 2008 2.5T XC90
http://clubvolvo.ru/showthread.php?t=105896&page=5
Frank65
Year and Model: 2006
Post by Frank65 »
:D this helped me i went to auto zone bought gasket material makeri took my.old houseing off and drew my own and put it back togeather if this helps i have listed a pic of my 06 volvo s60 gasket houseing so draw that out and u will have your replacement. .hope this works as i had the same problem fixed for 5 bucks if u have all the right tools
Thermostat gasket housing
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
I have opportunity to buy brand-new 2004-2006 S60 stat for inexpensive price but browsing FCPEuro website etc., it looks like Volvo posted 2 separate PNs for Thermostat: 2002-2004 S60 vs 2005-2009 S60.
I put together photos so you can see.
Same engine, same 90-degree C tstat etc.
Does anyone know the actual differences are?
PS: I just want to get the inside tstat itself and ECT from let's say 31219205 and swap into my 2007 S60 car.
Just want to know the differences (other PNs). This is a good example that Volvo came up with so many different PNs for basically the same item.
Has thanked: 1505 times
Been thanked: 3818 times
The mounting flange to the block sure looks different to me
Post by cn90 »
@abscate,
That is optical "illusion" from the photos.
The moumnting flange to the block should be the same bc the Metal Gasket PN 8636573, is listed for all 2002-2009 S60 and 2003-2007 V70 P2 cars:
https://www.fcpeuro.com/products/volvo- ... 73#fitment
Post by cn90 »
So,
Went to my garage and looked at some old stuff...
On the LEFT is 2004 V70 tstat itself, on the RIGHT is 2005 XC90 2.5T tstat itself.
They look identical in every dimensions, down to the 90-degee C stamp.
I wonder what all these different parts numbers mean, also if someone here has 2 units from 2002-2004 vs 2005-later to compare with.
Post by cn90 »
Re brands...
I have always used Wahler bc this was factory brand.
I recently installed Facet brand in my 2006 S60 as a test, about $50-$60 online.
It is made in Italy.
So far so good.
Zero issues.
It came with the metal gasket in the box.
Facet is a less expensive option ($50-$60 vs $110 for Wahler).
Just put this out there for those who want to save some money.
