1985 240 Stumbling on acceleration
bloodrootfc
- Year and Model: 1998 S90
Confirm fix please. Still good?
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
It's called on "a wing and prayer" maintenance schedule.newmex999 wrote:If anyone has insight into this let me know?
Here: 1985 MAINTENANCE SCHEDULE DL GL TURBO
Engine Drive Belts
My 740 runs fine until I depress the throttle at cruise, then stumbles. Haven't checked id the ECU is turning the ejectors off (as it does at max MAF signal) but the air/fuel meter (added) DOES NOT deflect lean. Very little written on this.
Have done a lot to check everything else...have not checked fuel pressure because O2 does not seem to show lean...
- Has thanked: 987 times
- Been thanked: 1078 times
Have you checked fuel pressure and flow rate to injectors? Unless the fuel pump and fuel filter have been serviced/replaced you may be low on pressure or flow limited. Want to start a new thread for this issue?
- 1006 Views
Last post by wizard064
- 847 Views
Last post by Byron1985
- 500 Views
Last post by volvolugnut
- 3202 Views
Last post by OntheDL
- 3984 Views
Last post by englemancr
