Same goes for not snugging up the right hand intercooler hose on a 2002 XC70. I put mine together in the dark and had a hole about 6mm x 40mm where the hose wasn't seated. Car ran like crap but just like you say no codes.
I would have thought a boost sensor would have given it away.....
Gah, blew up intercooler housing last night at 17psi Topic is solved
precopster
- Year and Model: Lots
- Been thanked: 128 times
Re: Gah, blew up intercooler housing last night at 17psi
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
I was also wondering about that, with the blown IAC hose it had to run very rich... but also no code.
850 T5-R '95 auto
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
post pics of the FMIC setup when you get it! i love fancy gear.
i think you might be able to get the epoxy to seal up the crack if you epoxy something _over_ the crack - bang a sheet of thin aluminum over to shape it and clamp while it cures, or something to that effect. it would still be a temporary solution, but maybe you could treat yourself to a few extra psi. and if you polish the aluminum, you can tear off the bottom of the bumper and pretend it's an FMIC until you've got the real deal going.
- Has thanked: 2650 times
- Been thanked: 1240 times
Will do.j-dawg wrote:post pics of the FMIC setup when you get it! i love fancy gear.
j-dawg wrote:...and if you polish the aluminum, you can tear off the bottom of the bumper and pretend it's an FMIC until you've got the real deal going.
To follow up on this and mark it
Solved, I ended up replacing the intercooler with an OEM Volvo unit a couple months later.
Solved, I ended up replacing the intercooler with an OEM Volvo unit a couple months later.Help keep MVS on the web -> click sponsors' links here on MVS when you buy from them.
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
Ouch. What tune are you running? Also hi! First time I've been on here in quite a while.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
Hi C. No tune. Just an "628" R ECU that probably doesn't make any difference at all. The boost comes from a manual boost controller I put on years ago.
