1993 960 Really poor fuel economy
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Re: 1993 960 Really poor fuel economy
Post by 93Regina »
Kappy5003 wrote:Maybe need to test coils and test oxygen sensor as to why poor fuel economy.
A coil-assembly can and do fail with time; here is all I could find: 960 Specs: 1994, and Ignition (coil) problem
Does yours have individual coils for each spark plug?
Kappy5003
Year and Model: 1994 960
Post by Kappy5003 »
Yes separate coils for each plug.
I'm running iridium plugs, I read somewhere they may be a problem, I ran them in my Motorcycle for around 30,000km until I had some carby issue, swapped out to normal and better idle.
I noticed recently that that idle seems a little higher than normal, after running for a whileI read that they can't be adjusted.
Would a faulty idle speed motor
(a) affect running rich/lean
(b) Impact on oxygen sensor.
Can an O2 sensor cause rich running, which I believe is happening, and not through a code, even though a code popped up some time ago, but hasn't returned since.
I just started car and noticed when I rev slightly and on back off i notice missing.????
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
If you have some copper plugs that are left over from before the iridium plugs try putting them back in.
1988 Volvo 760 Turbo Wagon
93Regina
Post by 93Regina »
Kappy5003 wrote:separate coils for each plug
They say there are wiring issues...etc...with that setup.
plugs
Always, use OEM's designated plugs....believe it or not, they work!
Vacuum Leak(s) can over-ride idle-motor. Use propane around intake manifold[
By chance, does your engine have an EGR valve? If so, it may be time to remove/clean it...also, the pipe work that goes with it needs to be examined, inside.
coil
With engine running, one might unclip each one, one at a time, and see if engine rpm drops more/less. It would be nice to have a digital tachometer.
Coil - Recently, I replaced a coil/wires on a 35 year old truck (GMC 7000), and it made a big difference.
Coils do fail with time...with engine running at night, one might look for sparks going off a coil.
I wonder if anyone has converted to a different ignition system setup...like maybe using GM's coil setup?
FlorenceTravis
Year and Model: 2015 Volvo V60
Post by FlorenceTravis »
Yes...with two O2 sensors, there will be a code on more up to date vehicles.
At the point when parts like flash fittings, wires, O2 sensor, and so on, have not been supplanted in quite a while, supplant them.
Fuel Injectors - Around here, it cost from $10.00 to $15.00 (US) (each) to have injectors assessed/clean; with more established vehicles, they ought to be pulled and tried.
Pressure Test - If all chambers are comparative, then, at that point your issues are identified with above, no doubt. You should also check what is an engine immobilizer
