2001 V70 XC - Rear Brakes Lights Do Not Come On Topic is solved
Wright Sounds
Year and Model: 2001 V70 2.4l Turbo
Post by Wright Sounds »
abscate wrote:You troubleshoot electrical stuff working backwards, using a VOM.
Thank you thank you thank you.
I have become a wiser man this morning.
I pulled the bulb out and connected two alligator clips the the hot and ground terminal at the socket connection.
I ran two wires from the clips up to the front seat. I connected them to the VOM and pressed the brake getting 11.65 volts.
I then connected the two wires right to the bulb holder and, presto, light.
Looks like I need new sockets/bulb holders.
Thanks for your advice.
Has thanked: 1610 times
Been thanked: 4068 times
Wright Sounds
After narrowing it down to the connection with the bulb-holder and socket, I priced new lighting & bulb assemblies and decided to find a way to make these work. In short, I added two jumper wires off the bulb-holder and soldered them to the metal plate that carries the hot and ground signal at the socket.
This is what mine looked like. Totally fine visually!
If you remove the bulb-holder, you can see two small slits in the metal lugs on the side. I fed a wire through one of the slits and up into the holder.
I then wrapped the wire around the lug that would be touching against the socket when installed. I soldered the wires to that lug.
I did the same thing to the other lug leaving me with a bulb-holder that looks like this.
After scratching the metal plate with a screwdriver, I soldered the wire connected to the lug on the right (when installed) to the metal down below it.
I soldered the wire from the lug on the left side of the bulb-holder to the metal plate on the left, above where the tail light assembly gets plugged in.
Here's what it looks like when installed, looking through the speaker hole. I but some silicone over the solder joints to protect and secure them a bit. I left enough slack in the wire to be able to pull the bulb holder out and change a bulb.
Now all my brake lights work and I'm very happy. Great forum here! Glad to be a new member!
Dave7777
Year and Model: 2001 Volvo V70 XC
Post by Dave7777 »
Would someone be so kind as to post the iPD or such part number for ordering new rear brake light relay? There are so many listed on the iPD website... I cannot figure out which one is the right on. Many thanks!!!
Dave7777
Post by Dave7777 »
Anyone??? iPD Part number for rear relays for the brake lights?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Dave7777 wrote: 04 Nov 2020, 09:16 Anyone??? iPD Part number for rear relays for the brake lights?
xHeart wrote: 15 Feb 2015, 10:42 The Recall Campaign No. 131 - Brake Light Relay was intended to replace combo with two singles.
The brake light and fog light are on their own relays. I believe, M15 and M16 respectively.
Check part number against the one in your car https://www.ipdusa.com/products/8753/11 ... o-30765041
xHeart
Post by xHeart »
oceanracer
Year and Model: 2002 v70 xc
Post by oceanracer »
also for reference the recalled relay write up from the xc70 forums
recall-brake-light-relay-replacement (1).pdf
(203.12 KiB) Downloaded 228 times
TRENDZ
Post by TRENDZ »
TAIL LAMPS.jpg (68.15 KiB) Viewed 726 times
There are no lower brake lights.
If you have a brake light functioning on both sides, your done.
The tail lamps are divided into upper and lower. The lowers have double filament bulbs, but they are for fog lamp function.
see diagram
