Do compression tests wet and dry and go from there.
Your head gasket maybe bad.
1998 Volvo S70 Coolant soaked on drivers side floor
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
If the car ever overheated, you likely have a bad head gasket. If the test was done properly, checking for combustion gases, and it's negative, you may have a chance.
I have had actual Volvo water pumps fail with the impeller to come off. I have seen a lot of bad water pumps, most of which just leak but some do loose the impeller inside the motor.
roscoerich
- Year and Model: S70 1998
Is there a way to check the water pump without pulling it?
Also, noticed the purple hose to the check air valve(which I think is the original) was pretty much deteriorated and not really even connected anymore. Would this be the culprit? I am going to check the air pump(original) as well, I heard some whining coming from it.
Is there a way to check the relays for the pump? Any advice would be greatly appreciated...
RoscoRich
1998 Volvo S70
1970 MGB Roadster Right Side Drive
2006 Hyundai Tuscon
1998 Volvo S70
2006 Hyundai Tuscon
