99 S70 n/a Jumped timing belt, now replacing head
- Has thanked: 1611 times
- Been thanked: 4075 times
Those little dings in top of the piston came like that from Sweden last century- don't worry about them
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
What is the website for Erie?
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Year and Model: Many Volvos
- Been thanked: 76 times
stephansvolvo
Thanks Lee
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You should NEVER NEVER NEVER NEVER NEVER use Scotchbrite pads to clean any internal engine part.
http://www.bobistheoilguy.com/forums/ub ... ber=563163
precopster
- Year and Model: Lots
- Been thanked: 128 times
Use nylon brushes with cleaning solvent. The Scotbrite pad is NOT for cleaning at all and I should have explained that. The fibres in the pad can find their way in between the rings. It is used to see if a burr exists by having the fibres catch. You could use any cotton cloth to do the same thing.rspi wrote:You should NEVER NEVER NEVER NEVER NEVER use Scotchbrite pads to clean any internal engine part.
If burrs are there they will rurn into hotspots and may result in piston holes. Running fingers over the valve flycuts can find burrs as well.
stephansvolvo
Erie didn't have what I need. I googled Clearwater and all i got was Clearwater volvo dealership.Ozark Lee wrote:The Tracy's True Soap writeup on a head gasket will cover about everything you need to do other than the differences on the timing belt tensioner which you are already familiar with.
Volvo 5-cylinder: How to Replace the Head Gasket
I don't know if you have already ordered the head from Erie or not but for about that same money you can get a reconditioned head from Clearwater. Even with a used good head I would want a machine shop to give it a once over and deck it if necessary but with a reconditioned head it is plug and play. Freight does become significant though since you need to return the core to them.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
Clearwater is Clearwater Cylinder Heads.
http://www.cylinder-heads.com/
As is the case with all rebuilders they have what they have at any given time. They do seem to do a good job of having most of the whiteblock heads in stock at any given time and I've only heard of a couple of instances where they needed a core up front.
stephansvolvo
Lee, I think this avenue just saved me about 700 bucks. Clearwater has a total head, cam, and cover for 565 SHIPPED with return shipping included. To go pull one from the yard and have it remand. Would have cost me about the same plus the time to pull it, which I do not have.Ozark Lee wrote:Clearwater is Clearwater Cylinder Heads.
Many thanks, I'll have it in about 6 days from tomorrow then I can use Roberts put it back together video along with all the other stuff I'm replacing.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
nyurch
- Year and Model: '98 S70GLT '02V70X/C
Sorry for the long wait for a post but it's been a hectic week.. Finally dropped the head in on Saturday, finishing everything up today. We had a little confusion with the intake gasket and it not having a hole for the bottom right bolt but it seems like all of the gaskets are that way. Have to do today: cylinder head gasket, putting on the cams, reconnecting the timing belt and odds and ends and seeing if she fires up. This is kind of nerve wracking. Total I'm in is $870, but I still need to buy oil & antifreeze. I'm not sure if I mentioned it but we did have to drill a head bolt out. I have cleaned all the metal out, as I can't find anymore, would it be a good idea to flush the engine out? I have read so many mixed feelings about flushing. I'm ready for all of his to be over with and life to return to normal. Good thing that came out of all of this when I was at the junk yard getting a new timing belt cover I found a mint cd changer and wires all for $20 and my blue leds finally came in for my dash.
All I know is if this ever happens to me again, it's straight to the crusher.
- 17 Replies
- 3532 Views
Last post by Gilly
- 12475 Views
Last post by SuperHerman
- 1702 Views
Last post by jimmy57
- 984 Views
Last post by carboncow
- 2648 Views
Last post by Nick3501
