I think you are playing Russian Roulette.
At 250K and with overheating symptoms, I'd personally get a new Aisin WP and move on.
1998 Volvo S70 How to check water pump without pulling?
- Has thanked: 311 times
- Been thanked: 817 times
Yes, if the water pump is in any way bad then replace it. I think that has been made infinitely clear here. But if it isn't, i.e. if the overheating symptoms go away with the ECT swap, then waiting a short while on the pump is not a big deal. OP can't just "replace the pump and move on" if the pump is not the problem.
greenman86
- Year and Model: 98 S70 T5-M
It sounds like you may have the head gasket going out on you. You mention the expansion tank boiling over in one of your previous posts. I would not be surprised if it was the case especially at the mileage you have given.
That's a good call but check the whole thread: the coolant test is negative for exhaust gas contamination.
northernlights
- Year and Model: 850 Turbo 1994
- Location: Florida and/or Raleigh NC, depending on the day
- Been thanked: 8 times
greenman86 wrote:It sounds like you may have the head gasket going out on you. You mention the expansion tank boiling over in one of your previous posts. I would not be surprised if it was the case especially at the mileage you have given.
Head gasket, cracked head, cracked block or similar was my first thought also given the circumstances.erikv11 wrote:That's a good call but check the whole thread: the coolant test is negative for exhaust gas contamination.
Is there a fitting on the block that you can attach a pressure gauge to? I think usually there is a coolant drain fitting under the exhaust manifold on the engine rear. If your water pump is really dead then you will not have pressure in the block when it is cold after startup. No flow = no pressure.
This thread is actually a continuation, I too thought head gasket right away but OP tested it twice for combustion gases (https://www.matthewsvolvosite.com/forums ... =1&t=69181).
That's a neat trick about checking pressure, there is indeed a fitting on the block.
precopster
- Year and Model: Lots
- Been thanked: 128 times
The suspense is killing me on this thread
roscoerich
- Year and Model: S70 1998
Sorry for the delay. Had to be out of town for work over the holiday weekend. I finally replaced the ECT yesterday and no more over heating problems. Cannot believe it was that simple- even though I had replaced it about 2 years ago, I was expecting the worst. I will take heed to all the advice of replacing the water pump as soon as I can find the time. I can't thank everyone enough for all your help! Thank you! Thank you! Thank you all!
Now to try and pass inspection.....
RoscoRich
1998 Volvo S70
1970 MGB Roadster Right Side Drive
2006 Hyundai Tuscon
1998 Volvo S70
2006 Hyundai Tuscon
- misha
- Has thanked: 155 times
- Been thanked: 432 times
As long as water pump is not leaking and cooling system is working as it should...leave it alone.
Mine is still original and it will be replaced soon because it started to leak a little around shaft.Not a big deal....few drops of coolant from time to time.
However...if you are going to replace it,use Hepu,SKF or Volvo pump.
Replaced ect sensor from 2 years ago.....was it oem or aftermarket?Only ect sensors which can be safely used in these cars are Oem which is made by Valeo and Vernet.Nothing else will work or last.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Good job sticking to the basic diagnostics routine and not just blindly replacing the water pump. Had you done that you would have been *really* frustrated!!
I agree with misha, the OEM pump is well known to last a very long time, you don't need to be in a hurry to replace one that shows no symptoms of failure but you will want to at least check it periodically for weeping.
