2000 V70 XC is a poly upper mount really a good idea?
dosbricks
Been thanked: 4 times
Post by dosbricks »
Okay, once I get it going straight, I'll try using an air impact tool. That should draw it in PDQ if I'm careful not to overdo it.
I got my last Lemforder all the way in with oak blocks and a bit of WD-40.
dosbricks
Post by dosbricks »
erikv11 wrote:Yes Dos, that freezer trick has been recommended before, many people swear by it ... great minds think alike!
https://www.matthewsvolvosite.com/forums ... hp?t=43089
etc.
About 55 years ago, I watched my dad easily drive in bearing races with a brass drift by freezing the race and warming the hubs in the oven. A job otherwise impossible without a press. He learned lot of self-reliance in the Great Depression. :wink:
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
My other thought for next time is: using a wire brush on a drill, I will clean the inside of the bore and hopefully remove a bit of the metal. This way the new bushing can slide in a bit easier.
The tolerance is simply too tight for nothing.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
My press tool is made from a long bolt and a couple old rear shock mounts, they have good diameters for this job.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I installed the bushing using my bench vise and a bit grinding on the bushing's shell so I can start it easier.
85 GLH, 367 whp
00 Insight, 72 mpg
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
erikv11 wrote:They wear out quickly. I think at 60k you were very fortunate, on my cars the OEM mount lasts more like 40k. Maybe because I don't drive so many miles per year.
I know from experience that the upper torque mount won't last long even if it's a Volvo factory mount if you don't replace all the other motor mounts. The upper torque mount needs the assistance of all the other mounts or it will wear out quickly doing the job of absorbing the shock and vibrations on it's own. I always go factory unless poly is needed for a performance, if you have have a modified V70 or S70 that would benefit from the polyurethane motor mounts then by all means go ahead. I have a 1999 5thgen Prelude Base model with a factory 5speed, I've done some minor modifications to suspension including polyurethane sway bar bracket bushings front/rear and in my opinion I can notice a slight difference around on/off ramps. This generation Honda Prelude is known for it's superior handling in it's class and actually won an award for it's handling in it's class. I have front/rear upper strut tower braces and I'm getting front/rear lower tie braces w/polyurethane bushings. The V70 and S70 have great handling ability from the factory, with the right suspension modifications you can imagine the possibilities.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I agree the non poly mounts are a royal pain to install. I tried the freezer trick, it didn't help much. The 3/8" bolt I used in the press I made stripped. I had to use a m12 bolt and lots of oil. Next time I will sand the od with rough then smooth sandpaper. Way too tight of fit. 2nd car I installed poly so I don't have to deal with hassle, yes more vibration but I dread doing the install again so it stays
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
