that could be it. i always thought that was an odd set up. the owners manual mentioned the light being on though. hey if it blows cold air i'm happy.
thanks again,
Doug
When AC goes out...
A/C Compressor Clutch Gap Fix
that was exactly what was wrong. thanks.Ozark Lee wrote:Are you sure you are actually turning it off? On the electronic climate control unit the A/C light illuminates in the Off position rather than the On position.
i went for a 20 minute test drive and it blew cold air the whole time. i shut the car off to run into the post office but when i came out it just blew hot air. when i returned home i shut the car off for about 5 minutes and when i restarted it i had cold air again. any suggestions?
- Year and Model: Many Volvos
- Been thanked: 76 times
Measure the A/C clutch gap with a feeler gauge set. The gap should be under 0.020. If it is larger than that the A/C clutch needs to be reshimmed. There is the really correct way to do that and then there is a real easy ghetto way of doing it.
What are your pressure readings compressor on and compressor off? You could have actually overcharged the system as well which will make the compressor run hot and then the thermal cutout will disable it until it cools again.
with a/c on gauge was reading about 41. probably not the correct way of doing it but i got it down to exactly 35. it was blowing cold air the entire time. i shut the car off for a couple of minutes then restarted and it was blowing warm air again. with the a/c turned off the gauge was in the red.
41 is high for a running pressure - 35 is in the ballpark depending on the ambient temperature.
Your next check is the clutch gap.
Here is the proper way to fix it - See N8-50's .pdf file:
http://volvospeed.com/vs_forum/Ac-Therm ... 76833.html
Here is the ghetto procedure:
http://volvospeed.com/vs_forum/index.ph ... opic=80181
delagarzaeric
- Year and Model: 850 GLT 1997
I'm trying to recharge my a/c but the hose will not lock on the refill fitting. Anyone else have this problem?
Welcome to MVS,
It is more of a hose fitting problem than a Volvo problem but yes. Pull back very hard on the female fitting collar, press the connector hard onto the male connector, and you should be able to get it to seat. You will feel the snap upon releasing the collar when it is correct.
It is all the same. I just buy the cheapest house brand stuff I can find from Advance or O'Reilly.
- 720 Views
Last post by lummert
- 1928 Views
Last post by rb61
- 805 Views
- 939 Views
Last post by GreenMagicMan
- 43 Replies
- 8854 Views
Last post by charlie33
