Worth a try before spending more money! Might also be worth considering running a can of Seafoam through the fuel system. If I am doing a long trip in any of my cars I usually do this, even though all my cars are well serviced. We do a lot of short runs and city driving so I don't believe it can do any harm, even though we use Premium (91 octane) gas. Even though your tank was fairly empty when bought it could have had moisture/condensation in the tank from sitting.
99 v70 glt running rough
- Has thanked: 2210 times
huzzsaba
- Year and Model: 2004 volvo xc90 2.5t
Just a quick update. started the car to move it out of the garage and got code P0305. Previously I got code P0302 and I swapped the coil from 2 with 5 and the code followed. As a test, I disconnected the coil while the car was running and it did not change the the way the car ran! Hopefully I have narrowed it down to a bad coil (fingers crossed)
I am picking up another coil today. will post the outcome later today.
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
1998 Volvo s70 T5M
huzzsaba
Success!!! It was the same coil that cause p0302 and p0305 when I moved it to cylinder 5. Replaced it with a used one and its working fine now! Its funny how I was able to run the car for minutes and no codes would show up which is why this one took a long time to figure out.
Just have to get the exhaust on and it should be set for safety and emission test!
Thanks for all the help!
1998 Volvo s70 T5M
1998 Volvo s70 T5M
- 11 Replies
- 2390 Views
Last post by jerseykat1
- 1420 Views
- 887 Views
- 12 Replies
- 2824 Views
- 1366 Views
Last post by Gymbo
