Timing Belt Job Gone Wrong... '99 S70 T5
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
That's exactly how it sounds! I'm thinking you're right with the car having lawnmower syndrome. We're going to get back to work on it Saturday, so I'll let everyone know what happens. I'll get that tensioner properly aligned and fix the lawnmower syndrome.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
It may well be *only* LMS but always good to sort out the timing then proceed. :)
bmdubya1198
erikv11 wrote:It may well be *only* LMS but always good to sort out the timing then proceed. :)
That's my reasoning. I want to make sure everything is right!
beigg
Year and Model: 850 97
Post by beigg »
Having the factory mark on each cog and incorporating one on each of your own before removal can aid in putting vvt to the last known ecm position.
ugh smh 850 Turbo fridge
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Listened to the video- My S70 a few years ago did that with a bad throttle position sensor. If you unplugged it by chance, make sure it's plugged back in - that could be the only thing wrong. Did you read your codes after the TB re-change and no start?
angelglo
Post by angelglo »
I'm just throwing this out there but do you have pressure at the fuel rail?
jantt
Year and Model: C70 2000
Been thanked: 2 times
Post by jantt »
I have a 850 GLT 1992 without VVT so don`t know if it is the same.
My marks on camwheels was way off.
Set the crankshaft on mark and lock the cams in the back and see to that cyl. 1 is on top.
That worked for me.
Factory cam marks are not spot on, but mine engine is running perfect.
bmdubya1198
angelglo wrote:I'm just throwing this out there but do you have pressure at the fuel rail?
I haven't checked for fuel pressure.
bmdubya1198
MadeInJapan wrote:Listened to the video- My S70 a few years ago did that with a bad throttle position sensor. If you unplugged it by chance, make sure it's plugged back in - that could be the only thing wrong. Did you read your codes after the TB re-change and no start?
Every time I go over there I forget to bring my scanner... so I haven't checked for codes. I don't believe I unplugged anything other than the coolant level sensor.
angelglo
Post by angelglo »
you may as well run different scenarios. fuel, spark, timing. Fuel pressure can be as simple as unscrewing the cap and pressing the shredder valve. If you do not get pressure at all, that is not good. Though a fuel pressure tool would be ideal.
