Dash Cam thought? Hardwiring into power.
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
So confused, so if I tap into the Red wire on the accessory plug under the dash and then the black wire for ground, I should be good? I think this is what a buddy did to hook up his pod gauges as well.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Yup! Should be fine - note that that will give you a "hot all the time" connection, which might trickle some charge out of your battery if you leave your cam running, but other than that, you're good.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Speedy - Refer to these diagrams - These are the wires that should appear at the yellow connector in your car.speedyt5 wrote:So confused, so if I tap into the Red wire on the accessory plug under the dash and then the black wire for ground, I should be good? I think this is what a buddy did to hook up his pod gauges as well.
Your dash cam installation instructions should indicate whether your cam power needs to have constant or switched power.
Select the large Red wire in Pin 1 position for constant power
-or-
the smaller Brown/Orange in Pin 2 position for key switched power.
- 797 Views
Last post by chris S60LaRosa
- 1349 Views
Last post by mrbrian200
- 2734 Views
Last post by erikv11
- 26 Replies
- 5133 Views
- 799 Views
Last post by SVO LOU
