1996 Volvo 850 tries to start when I connect the battery cables
Myvolvo850
- Year and Model: 1996 850
It's deffinatly electrical... I decided to just wire I a toggle switch for the time being... works perfect..I'm dreading having to chase down that wire
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
A great point about aftermarket systemsOzark Lee wrote:I don't think that you have indicated but do you have any aftermarket equipment installed in the car? A bum aftermarket alarm/remote start setup might cause your problem and it will be difficult to sort out. I just wound up yanking one completely out of my son's 850 after it wouldn't start.
One other thing to do is remove the 210/211 relay and see what happens. That will tell you which side of the firewall to focus on. With the relay removed it should not crank with the key and it certainly shouldn't try to start without the key. If it still tries to start with the relay removed then work your way forward through the harness under the hood.
and some excellent advice about troubleshooting.
Isolate your problem and conquer that sucker!
