1996 Volvo 850 tries to start when I connect the battery cables
Myvolvo850
Year and Model: 1996 850
Post by Myvolvo850 »
So I replaced my starter all was well for about a month.. then I go to start my car and the starter keept turning and turning even when i tried to turn it off!!! i had to jump out and dissconnect the battery... so I figured the starter was bad and replaced it again as soon as I tried to connect my battery cables the starter turns over even though there is no key in the ignition. I also replaced the ignition switch. I put a test light on the small green wire that connects to the starter and it has constant power.. I'm not sure if that's good or bad.. but the big problem is I can't even connect my battery now with out the car trying to start. Please help!!! :(
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
First thing to do is to disconnect the starter solenoid wire, then you can hook up the battery and troubleshoot and see why that wire is energized.
I included the starter wiring diagram for you.
starter bosch.pdf
(127.36 KiB) Downloaded 193 times
85 GLH, 367 whp
00 Insight, 72 mpg
Myvolvo850
Are there any inline fuses that would cause this problem? I'm not getting any engine codes for a transmission sensor... but my speedometer does only work on an occassion...
tryingbe
Has thanked: 1 time
Post by tryingbe »
No inline fuses. Follow the diagram with a multimeter and see where you're getting the 12v from.
85 GLH, 367 whp
00 Insight, 72 mpg
Myvolvo850
So where ever I'm getting the 12v from that's what's bad?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Assuming that the starter is wired up correctly and unless the service starter connector has a wire running from it to the battery it pretty much has to be the electrical portion of the ignition switch. You can unplug the ignition switch to verify that the problem is happening there. Be careful removing the connector on the ignition switch that you remove the whole connector and not just the cap. If the cap is removed the wires come off and they are tough to get sorted back a out.
The green wire with the red stripe should go to its own terminal on the solenoid with no other wires on that same terminal.
Has thanked: 2199 times
Been thanked: 1851 times
Some of the aftermarket starters have an extra connection on them. It allows the battery cables to short across it and make the connection continuously live. Take the battery cables off again at the starter and look at it and compare to your old starter. If I recall I had to break/cut the extra spade type connector off to make it work normally.
Has thanked: 1609 times
Been thanked: 4065 times
Almost certainly ignition switch, electrical part
Remember the replacement starter worked ok for a month so something gave out
Myvolvo850
Thanks for all the feedback I'm going to look into it now wish me luck
Myvolvo850
Should the red battery cable show power to the starter at all times?
