Can't find the back 2 drains. Rear driver side carpet is wet.
There only seem to be 2 drains in the roof and they go forwards.
The left corner drain does seem to be blocked when I blow through it with a tube. I tried sticking a wire down but not much movement. Drain chemical or boiling water any use?
Any ideas why the back would be wet as well?
The spare wheel is dry so it's not a leak from the tailgate, m
Water in footwell
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I believe the water can leak from drivers footwell to the rear passenger one, under the carpets.
qwertyjjj
- Year and Model: V70 2004
- Has thanked: 1 time
Ok. This is still happening in the winter from snow melting.
I poured water in the roof drains in the summer and it all came out. So, what else could the leak be from?
Snow builds up on windscreen as well.
- 1008 Views
Last post by RickHaleParker
- 5196 Views
- 1069 Views
Last post by SuperHerman
- 3557 Views
Last post by volvolugnut
- 916 Views
Last post by bigbrain
