Make sure the bracket that is underside of intake near the TB is not being pinched. If it is, it'll created a nice source to a vacuum leak... If you have not tweaked or cracked the manifold from the torquing unevenness.
And a final shout out to beigg, again you were spot on. I truly appreciate you taking the time to help me out.
1997 T5 Major PCV Fail, pinched bracket, cam sensor wiring Topic is solved
T5 Tony wrote:Make sure the bracket that is underside of intake near the TB is not being pinched. If it is, it'll created a nice source to a vacuum leak... If you have not tweaked or cracked the manifold from the torquing unevenness.
No problem T5 Tony. We appreciate the follow through with a follow-up to a repair's outcome. :cheers:
ugh smh 850 Turbo fridge
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Congratulations! Good to hear you got her smoothly running again.T5 Tony wrote:I just got home from a 30 mile drive from my parents' house. Success! I really want to extend my heartfelt thanks to everyone for their advice and wisdom. Sleddriver, you were right on the money concerning the camshaft position sensor's connection. It literally crumbled in my hand and I spent a good 20 minutes digging the remainder out of the female end.
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 1611 times
- Been thanked: 4071 times
Beigg....
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Manifold, related parts and gasket are likely culprits, as pointed out. I tore my manifold gasket near the front stud where the fitment is tight. But you found the culprit, which is good. Took me a couple of tries as well. After my attempts I got to the point where I could do the job in about 45 minutes!
- 2049 Views
Last post by Dmck
- 1286 Views
Last post by ThinAir
- 969 Views
Last post by brbrob
- 326 Views
Last post by Jerrycan
- 6437 Views
Last post by volvolugnut
