DIY: x70 Projector Retrofit
Improve Headlight Output with Projectors
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I used the Morimoto Mini H1 7.0 kit.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
FlyingVolvo
I used the clear lenses that came with the ABM projectors I no longer use. Not sure where to buy clear lenses new. Maybe eBay?
2023 V60 T8 PE
2023 V60 T8 PE
fasteddyT5
- Year and Model:
I did a similar retrofit a few years ago on a car I just sold using an FXR projector kit from the retrofit source. I sourced the clear lenses from autolampsplus.com for $108 at the time.
They are not listed on the website, which is hosted on ebay, so you need to email or call them to ask if they can still get them. I think that they were being sourced as replacements lenses for ABM's (non-HID) projector headlight buckets. I originally did the conversion back in 2012, but I did need a replacement lens for one that got cracked by a stone maybe 2 years ago and they were still able to get them then. As far as i could find they were the only aftermarket seller of the clear lenses. Although they likely cost a lot more you could likely get replacement lens from Volov for the "jewel" headlights available on later C70's.
codytheflash
- Year and Model: 1999 V70
FlyingVolvo
Very nicely done! (Best color wagon too
) What are those LED bars on your fog light grills?
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 317 times
- Been thanked: 531 times
Glad I came across this thread! I need to grab a set of headlights from the junkyard and do this. I've been wanting to put HIDs in my car, but I didn't want to just make a light bomb out of the stock halogens.
Hello - Sorry as I know this is an older post. I have a quick question, to replace the bulb in the projector portion do you have to remove the light from the car, then remove the lens? Can it be replaced without disassembling the light?
Thanks
Happy 2018 all
Thanks
Happy 2018 all
- 906 Views
Last post by diggler30
- 996 Views
Last post by c70_lindsay
- 2252 Views
Last post by precopster
- 2045 Views
Last post by Baptiste1106
- 24 Replies
- 8259 Views
Last post by bowtie
