Instruments of Death P2 Volvo Jack
This topic is in the MVS Volvo Repair Database » Are Volvo Jacks Dangerous?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I haven't changed a tire since I was in my 20s and yes, I/we used the awful jacks of the day that came in the car.
However if I had to do this again these days, I would figure out a different way.
I would NEVER use a scissor jack again!
I know enough now to know this is a real bad idea!!!
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
Haven't ever had a problem lifting the car with the OEM jacks. That said, if I'm going under the vehicle I ALWAYS put it on jackstands.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Always good to be reminded of the very real dangers of working under a car.
So is everyone who keeps saying "floor jack only" or "jack stands only" actually carrying a floor jack and two jack stands in the car at all times, for the pesky flat tire situation? This thread is about what to do when you are on the road, what to have in the car to make that situation a little less dangerous. Doesn't seem like there are any good solutions, alas.
zombielinux
Year and Model: 2007 XC70
Post by zombielinux »
Has thanked: 1613 times
Been thanked: 4078 times
You loosen the nuts/bolts
Spare is out of the trunk or hole, ready to go.
Block and jack, tire off , spare on. Get two nut finger tight asap. Elapsed time car is without wheel, 30 seconds or less
JRL
Post by JRL »
Call AAA
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
abscate wrote: 06 Jul 2017, 20:14 You loosen the nuts/bolts
Depends. Guessing the right height for the donut is easy. But if you're trying to get a full-size spare in there, you need to keep jacking and jacking and jacking. Which reminds me,I really should put one of spare scissor jacks in there...
Retired:
2015 Volvo S60, T5, 85K
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
"...I really should put one of spare scissor jacks in there..." Do whatever will work but make sure your scissor jack has a saddle which will work somewhere under the car.
theWIFES_S70 wrote: 06 Jul 2017, 21:34
If you rest the spare against the wheel being changed , you can lift it until the hub is above the spare hub. If you let. Your car communicate, it eliminates guess work! :D
theWIFES_S70
abscate wrote: 08 Jul 2017, 02:18 If you rest the spare against the wheel being changed , you can lift it until the hub is above the spare hub. If you let. Your car communicate, it eliminates guess work! :D
And ruin my paint??? :) Actually, this is not a bad idea. I hate the P80 jack. One of my first jobs, it tipped over on me. It was the scariest thing because the car started to fall to one side so slowly... I didn't have a floor jack yet so I would always start work on the car with the Volvo jack (almost all of rspi's videos, he jacks up his car with the Volvo jack...) and two other scissor jacks (just to be safe) before getting the car on jack stands. Luckily I was able to get a scissor jack under the car before anything serious happened. Needless to say, I haven't used the Volvo jack since.
I chock wheels with those rubber chocks from Harbor Freight and stick a 50lb bag of sand behind one chock and a few cylinder blocks behind the other. Safety first!
Retired:
