P2 Clutch pressure plate flywheel release bearing slave cylinder - 2005 V70NAM56 clutch subframe engine drop Topic is solved
Has thanked: 1609 times
Been thanked: 4063 times
Wear/damage report
Clutch disc thickness new 9.5 mm
Old thickness 4mm. Right down on rivets.
Release bearing completely destroyed. Looks like it flew apart and detonated. Spring loose, bearings scattered. All over.
No cracks or scoring on either pressure plate (pp) or flywheel, both replaced.
Interesting, this car has the dual mass flywheel but not the self adjusting clutch, just a standard PP
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Is it light in operation Steve?
Have never seen a P2 manual or driven one.
It is the lightest shifting car I have ever driven, period. There is a huge counterweight on the shift levers if you look in the pics.
Well "buttoning up" took a long 1/2 day today, just to get the subframe back in and the engine onto it s mounts
Two exceptions
One of the exhaust plate bolts won't thread...minor
The top bolt on the RHS engine mount (engine side near firewall) won't thread either. Its lined up nice. I will run it with 2/3 and deal with it on a lift next time Im up.
I need a new lower torque rod and front engine mount.
Wheels and hookups this weekend.
I also lost half day to a cancer scare on the dog - which turned out negative
:-D
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Nice.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
Backdown on her wheels this am!
I Still need to:
Final torque on 14mm hub bolts on axles
Bleed clutch...that is new but should be easy
New coolant and hoses ..I'm just going to put in water for now, flush and do hose refresh in a week or two.
I also Have one bracket I can't Id.....anyone help?
On edit - it helps when you shoot pix as you go..
I think I have it - clutchslave cylinder mounting bracket - outside the trans case - PTL
Well, sneaked out of work at 1600, and just came back from ...
the test drive.
Did the last few loom brackets,.
Installed the clutch hydraulics - heads up to FCP who shipped me the wrong part, so put the old adapter back on. I bled clutch by just filling the master cylinder, loosening the 9mm bleeder, and pumping fluid up to a disposal bottle at the air cleaner, After about 20 pumps, I had clear new fluid with no bubbles, tightened bleeder, and felt pedal, It was really light but I could hear clutch action.
Installed MAF, air cleaner, tightened radiator hoses, filled with water (upcoming flush)
Reconnected battery....and ....vroom. Idled for 10 , topped off water.
Moment of truth - pushed the clutch down, which is feather light, then eased into first - no grinding. Eased foot and - HOORAY - Ive got a new clutch!! I drove around the block - the new clutch is so light you can depress by hand, using only your fingers.
I want to drive local for a few 100 miles, then recheck the major structural torques, but I think Im 98% done on the clutch job.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Congrats, Steve. Good work!
Also -> Amazon link
precopster
Well done mate. When you have a moment can you swing past and help me convert my T5 to a manual?......seeing as you know them so intricately now :D
Did you find out where those miscellaneous parts belong?
