YIKES!! 15 Qts. of oil to get home tonight Topic is solved
Has thanked: 1609 times
Been thanked: 4064 times
I don't think the cam hub has enough angular okay to cause interference but there is no way I would tell anyone to play that lottery
Idle will be fine, you will get a cam code error if the vvt isn't setup right, usually after a couple hundred miles
aaron1611
Year and Model: 2006 XC90 V8
Has thanked: 2 times
Been thanked: 5 times
Post by aaron1611 »
about to tear it all apart this morning to replace intake cam seals but when my crank is TDC my cam's are off by one tooth. it still runs and idles nicely. So, should I keep crank at TDC and then move cams one tooth over? or leave as is and proceed, obviously I'm not looking for the 100% fool proof Volvo fix but if it's just one tooth I've been reading that that is within min. tolerance and the car will drive fine but I might have to clear codes. Thanks, again.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
Post by aaron1611 »
fixed the leak, it was the intake cam seal and aligned the marks and runs great but I got the cam code, ECM-643A. Not sure when I'll get another day to redo it but just glad it's not leaking oil everywhere.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Excellent. It's a low priority code so deal with it on a nice day at your pleasure!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
aaron1611 wrote: 26 Sep 2017, 18:59 fixed the leak, it was the intake cam seal and aligned the marks and runs great but I got the cam code, ECM-643A. Not sure when I'll get another day to redo it but just glad it's not leaking oil everywhere.
quite an episode, mine leaked but not that much.
aaron1611
Post by aaron1611 »
thanks everyone for your input and time. It's crazy, running all that oil through the cam seal really cleaned out the engine pretty well, so far the oil on the dipstick looks like vegetable oil it's sooo clear. I'm going flush the transmission fluid today, bought a case of Mobil 3309 and hopefully it'll run even better. thanks again everybody.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
