Are those ideas any fun?abscate wrote: 19 Jan 2018, 06:57I have some other ideas about improving transmission life...What I noticed with the S40 after resetting the adaptation was less wheel spin![]()
One bottle of Toyota T-IV in a transmission with original fluid
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
nickbw898
- Year and Model: xc702002
- Has thanked: 1 time
- Been thanked: 5 times
I'm going to stick my oar in here and rock the boat! My 01 XC70 is on 161,000 miles. I have always driven it hard, tow boats and caravans and I have done ALL my own work not just maintenance but major renewals like suspension (control arms, struts). I forget how many times I have done the Gibbon's flush on the gearbox. Each time I use 20 litres of 3309 (Manol from Germany) and use Vida Dice to read transmission temperature and check oil level is spot on. The transmission still shifts like new. I have once Cleared the adaptions and driven them to reset everything. I think fears of messing the box up with a "flush" (not power flush) are simply an 'old wives tale' - I will even stick my neck out and say I think 'drains and fills' are a waste of expensive trans fluid.
- Rattnalle
I'd say flushing 'more times than you can remeber' instead of the four or so AWs service intervals would recommend in the same distance is way more wastefulnickbw898 wrote: 19 Jan 2018, 11:45 I'm going to stick my oar in here and rock the boat! My 01 XC70 is on 161,000 miles. I have always driven it hard, tow boats and caravans and I have done ALL my own work not just maintenance but major renewals like suspension (control arms, struts). I forget how many times I have done the Gibbon's flush on the gearbox. Each time I use 20 litres of 3309 (Manol from Germany) and use Vida Dice to read transmission temperature and check oil level is spot on. The transmission still shifts like new. I have once Cleared the adaptions and driven them to reset everything. I think fears of messing the box up with a "flush" (not power flush) are simply an 'old wives tale' - I will even stick my neck out and say I think 'drains and fills' are a waste of expensive trans fluid.
QUARKS40
- Year and Model: 2010 XC60
- Been thanked: 2 times
OTabscate wrote: 19 Jan 2018, 06:57I have some other ideas about improving transmission life...What I noticed with the S40 after resetting the adaptation was less wheel spin![]()
No FAIR! Manny tranny swap on a 01 S40 is a pain in the *$$, not to mention importing a pallet of parts from breakers in the UK
2010 XC60 - P*, 3 Spoke steering wheel retro, Gearshift retro.
2001 S40 - 14T, BBTB, turbo back stainless DP, Upsolute, KW, 15mm rear sway, 17" Konig wheels, Custom Arctic Silver/Sonic Blue pearl paint, custom interior
- 1307 Views
Last post by alschnertz
- 1178 Views
Last post by difflock54
- 1874 Views
Last post by Volvo S80
- 6169 Views
Last post by jimmy57
- 712 Views
Last post by CIK7
