Volvo does have a torque value for some of the pipe clamps. It may be the intercooler ones but I can't recall at the moment. I use a 7mm socket and a 1/4" drive wrench as well as various lengths of extenders. The most important thing to me is using good quality clamps like the ABA branded ones.
I do like Oetiker clamps other than you get one shot with them to get it right but they do tend to spread the load more evenly.
I’m bad at screw clamps. Anybody use Oetiker clamps?
- Has thanked: 2197 times
- Been thanked: 1850 times
- Been thanked: 4064 times
In the Northeast, a non SS clamp will become single use pretty quickly. Look at the picture above of ,y lower radiator clamp. That one didn’t respond to either a 7 mm socket nor a screwdriver.Sveedy wrote: 15 Jul 2022, 16:03 Great in assembly settings, like a factory.
Not so great in everyday real world settings. And not re-usable. Might as well use a zip-tie.
I definitely carry hose clamps in the tool kit for a road repair but when I’m doing a cooling group refresh, it’s oetikers for everything
Turbo induction hoses get the Volvo brand special clamps. These are complex, not just simple band clamps.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
IMHO, that picture speaks more to a lack of maintenance than a problem with the clamp design.
I'm under my hood enough that I would have noticed that clamp rusting long long before it got to that state. But it does bring up another advantage to the worm gear type; you can disconnect the band from the gear housing and pass the band around the hose and back into the housing without having to remove the hose to slip it on. So in this case, the old clamp could have been removed and a new clamp installed without ever having to drain / disconnect / refill etc.
1999 V70 GLT
1999 V70 GLT
If you buy harbor fright knockoffs you have to pull the hose. The real oetikers can be installed onto exitsting hoses without removal .
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,abscate wrote: 21 Jul 2022, 11:19 If you buy harbor fright knockoffs you have to pull the hose. The real oetikers can be installed onto exitsting hoses without removal .
Why do you have to pull the hose?
Just wondering what causes this.
Knockoffs are closed band so you have to pull the hose to slip the clamp over the end. The higher quality ones can be released like a hose clamp, actually easier than a hose clamp, wrapped around , then clamped
The,single use, waste, and the tool requirement are the downsides of oetikers
Update. I’ve just refreshed my supply. If anyone wants the set of 42 and 45 oetikers for the main radiator hoses pm me and I’ll usps them to you. You can buy them from Belmetrics, a small order will add $10 shipping
You will have to share your address, ssn, and bank routing numbers with me to get these. I had a much-too-long text stream with someone who wanted SAS diodes but didn’t want to give me their address.
Hey! I’ve been judged here…IMHO, that picture speaks more to a lack of maintenance than a problem with the clamp design.
Adding the obligatory picture to all oetikers discussions…..
- 14 Replies
- 1583 Views
Last post by BEJinFbk
- 38 Replies
- 13775 Views
Last post by 454cid
- 362 Views
Last post by MarinerMan
- 3033 Views
Last post by yair
- 15 Replies
- 4154 Views
Last post by erikv11
