Front Struts and Rear Shocks
What brand are you running?
Bilstein
25
33%
KYB
3
4%
Boge
2
3%
Sachs
16
21%
Monroe/Gabriel
12
16%
NAPA
1
1%
OEM
17
22%
Total votes: 76
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
An XC has self-leveling or nivomat shocks in the rear so what you propose won't work for the rear, though should work fine for the front. For the rear, you will have to get the OEM nivomats which are quite expensive.
drummerboy
Post by drummerboy »
Do you have any sugestions on brand or where to look for the rear nivomate. I went to a dealer and it was over 1,000 for them.
http://www.fcpgroton.com/CSV70/csv70shocks.htm
Believe you'll find them in that link....follow the directions for correctly identifying the shocks you have.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
drummerboy wrote:Do you have any sugestions on brand or where to look for the rear nivomate. I went to a dealer and it was over 1,000 for them.
They're very expensive and the only ones are OEM, made by Volvo
casmoginst
Post by casmoginst »
My 95 850 Turbo is running "IPD Front and Rear Sway Bars and End Links" my Struts "Koni FSD's" my Springs "Eibach Pro" and I love the ride.
Jonathan Summers
charleskennedy23
Year and Model: 1998 V70 T5
Post by charleskennedy23 »
I put the monroe shocks on my car because I didn't know any better. Don't do it!!! I'm going to run them for a couple of year and change them out when I get a year without a lot of maintenance costs. Supposedly they get better with age… we'll see =/
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The 5th digit of your VIN determines which Nivomat part number will suit your car. Check this link: https://www.amazon.com/dp/B001G8HTOU/re ... jvb1NPBRNX
Not so expensive if you shop around. Try Tasca parts for a price.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
Bill S70 T5 wrote:
Anyway, went with the TME sports springs, and Koni Yellow adjustables.
The handling is great, a little firmer than I'd anticipated, but overall worth doing, I'm pleased with the results. Surprisingly the TME springs didn't drop the inch I'd expected, in fact didn't move a millimeter!!, all measurements are exactly as before, I didn't use the camber adjustment bolt at all as nothing moved.
Bill
I have a similar setup: give it a few miles to "Settle" (500/1000m). It will feel much different (probably for the better).
-One note of caution: since you had someone do the work: how do you know what they set the "stiffness" too? I had issues matching the rear to the front. (rears have to be removed to be adjusted). Also, the fronts are counter-intuitive: right LOOSY for stiffening the damper.
*edit: sorry thought you were the OP asking question and were new to the konis
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
