doing a PCV replacement
A FLAPS will have the release tool for about $10, that’s the easy way to get that done.
- dlundblad
- Year and Model: 2002 S60 2.4t
- Has thanked: 6 times
- Been thanked: 4 times
Torx with 10mm head would be even more awesome. My main concern would be torque though.. Maybe a machine screw would work?chrism wrote: 23 May 2018, 17:08The next time I do a PCV service I am going to explore the possibility of replacing the IM bolts with torx heads. That would mean slipping a skinnier tool in next to the thermo housing.Rattnalle wrote: 23 May 2018, 16:03 I used two short 1/4" extensions with "wiggle heads" and a regular 10 mm socket to get to the hard to reach bolt beneath the thermostat. Worked OK.
FWIW, I was able to get everything out just fine with a 1/4" SK wobble joint, a few extensions and a socket. No issues whatsoever.
Hers: Charcoal 2002 S60 2.4t 187k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Intake manifold bolts torque is really not that high. Genuine manifold gasket is made of some sort of a 'paper', it must not be fully crushed with torque. I think the torque for the paper gasket is 20 ft.lb which is pretty important
http://www.volvohowto.com/volvo-s60-v70 ... fications/
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
So far so good - got the new PCV box installed with minor problems. I had to pull the fuel rail and I'm glad I did because almost all of the O rings were bad. And The small hose that leads from that odd fitting that is held on by a 17MM banjo bolt was rotted. I'm not happy with the fit of the "regular" type of hose clamps, but they work. I can't find the embossed type or the Oetiker (sp?) type in town.
So how do I get the fuel line back between the 1 and 2 runners? I got it out, but have no idea how I did it.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
I think I did. I was trying to wrench and at the same time, deal with other pressing issues while working on the car, so I kind of forgot how I did it.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
You can bend that fuel line gently, keeping the bend radius >15 cm to prevent kinking, to clear or install the intake manifold. It’s highquality thick steel
azureblue
Done! It started right up, with no leaks. Almost scared me. In addition to the PCV job, I repaired bad Fuel injector O rings, Rotted hoses, put a clamp on the breather hose at the top of the cylinder head, Cursed the banjo bolt (french profanity seems to work best to get it back in), put an O ring in the Power steering high pressure line fitting, and fixed a leak at the bottom of the oil stick tube. It got more involved than I planned, but it was worth it to fix the other stuff while the manifold was out.
Much thanks to all for advice and suggestions. Your help is greatly appreciated
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
You put the banjo on the fitting, with the two copper washers, then you put a sacrificial orings on the bolt to hold it together. Once you get the banjo started, snip the oring and pull it off.
I spent the same three hours figuring that out.
- 784 Views
Last post by dmack87
- 15 Replies
- 2764 Views
Last post by SonicAdventure
- 2203 Views
Last post by JMEngland88
- 24 Replies
- 4874 Views
Last post by petermetzger
- 831 Views
Last post by 98v70dad
