Volvo 855T popping during deceleration
sventastic
Year and Model: 1996 854R
Been thanked: 6 times
Post by sventastic »
RickHaleParker wrote: 26 Jun 2018, 18:20 K&N gets the extra power by reducing the filtering capability. In other words it reduces the intake airflow resistance by allowing larger and more particles to pass. The particles are like sand in the engine, they increase wear and tear on the engine.
If you can provide data or analysis showing that this is true for the filters used for these cars (both OEM and K&N/etc) then this take would be worth something. Otherwise it's just conjecture. I'm not saying the K&N is good or bad or that your point is wrong, just that it doesn't mean anything without actual proof, which I would be very interested in since I use a cone filter on my 850R
1996 854R | M56H | 16T | 274k | BC, Canada
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
This is exactly why I removed the PO's aftermarket oiled filter. And besides, it's easier to replace a $10 paper filter once a year in under 2 minutes, versus cleaning and re-oiling a K&N filter every 6 months (and then hoping you did it right). The P80s already have a huge air filter compared to other cars, not sure how much more airflow you really need.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Plus it's really easy to over-oil them. Then that just leads to a gunked up MAF sensor.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Filtering efficiency is a measure of the filter’s overall ability to capture dirt.
Accumulative Capacity is a measure of dirt holding/loading capacity before reaching the maximum restriction limit.
Accumulative Gain is the total amount of dirt that passed through the filter during the test.
Source
I have seen other side by side comparisons where they had the test conditions for the Marketing (Not ISO 5011) Filtering efficiency claims. In every case K&N fudged the filtering efficiency test by using a particle size larger then what is used in the ISO 5011 filtering efficiency test. In other words K&N fudges the test by changing the test conditions to produce marketing claims that makes their filters look better then they are. K&N then advertises the higher filtering efficiency numbers without disclosing the non-standard test conditions.
Active
Past
henrysin44
Year and Model: 1994 Volvo 855 Turbo
Has thanked: 2 times
Been thanked: 3 times
Post by henrysin44 »
RickHaleParker wrote: 27 Jun 2018, 14:49 Filtering efficiency is a measure of the filter’s overall ability to capture dirt.
Source
Then it's final, K&N isn't going within 500ft of my 850!
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
WhatAmIDoing
Yikes. It's graphs like that that make me feel bad for leaving that oiled filter on for as long as I did.
Has thanked: 1611 times
Been thanked: 4075 times
Kobayashi & Naru
If you don’t like the result, change the test.
bmdubya1198
abscate wrote: 28 Jun 2018, 14:40 Kobayashi & Naru
I like that. So where's the chart for flow ratings? :mrgreen:
RickHaleParker
WhatAmIDoing wrote: 28 Jun 2018, 10:34 Yikes. It's graphs like that that make me feel bad for leaving that oiled filter on for as long as I did.
Take a white rag and wipe the inside of the air intake plumbing ... I'm sure you can figure out the evidence.
An old white sock is good for this, does the job and keeps your hand clean.
Active
Past
