That’s a brilliant idea. You know I never thought to try a can of starting fluid. Heck I’ve got two in the garage. That’s by far the best “base” test. (I was looking too far inside the box vs looking outside of it for somewhere to start).
Thanks
Cold start issues.
- June
- Has thanked: 523 times
- Been thanked: 261 times
I had a similar problem with my 2004 S80 T6. Only hard to start cold. My service department found a intermittent failure of the crank sensor. They said this I a known issue. When cold the contact was intermittent, and once warm the heat expands the area of trouble allowing contact. It didn't make sense to me, but fixed it. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
pb49415
- Year and Model: 1998 S70
Hmmmm. If worst case scenario, I’ve heard of other bizarre issues taking place when said “crank sensor” acts up. Depending on where it’s located and degree of complications involved I can probably do it myself. Was the charge you got from the stealership a hefty one? Just in the event I need to bring it in?
- June
$311.66 plus tax at my dealer. As I remember I waited for hours for the job to be finished so likely it was hard. Best part if it breaks again Volvo gives a lifetime parts and labor warranty so it will be on them... June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I've never heard of a bad or failing ECT setting a CEL. That's why when it tests out of spec you need to replace it. Also why it's difficult to diagnose, because you have to test it.pb49415 wrote: 27 Jan 2019, 06:37 One question about the ECT. If that were faulty, wouldn’t a check engine light come on? With an error code?
Knows enough to be dangerous
pb49415
Relay confirmed. Did the relay room temperature/ relay -7 in the freezer. Worked warm twice. Before and after freeze. I’m ordering an ECT just to have on hand. Thanks everyone for all your advice. It’s greatly valued!!
Paul
Paul
- 3113 Views
Last post by nucci480
- 589 Views
Last post by WhatAmIDoing
- 1978 Views
Last post by matomorizo
- 1298 Views
Last post by maverill
- 856 Views
Last post by erikv11
