Don't forget $$$$$$ and skill.Rattnalle wrote: ↑23 Jan 2019, 13:46 Speaking about what's possible with enough work.
https://engineswapdepot.com/?p=35398
How to make my V70 XC powerful?
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Re: How to make my V70 XC powerful?
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- Has thanked: 304 times
- Been thanked: 517 times
WOW! Talk about overkill!
8,600 RPM on a 5 cylinder sounds glorious!
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Well... I guess it’s not overkill if you really want to push those quarter mile numbers down...
So, the block is good for at least 1200 hp. Good news for OP!
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
And the moment the pedal is touched the entire rest of the drivetrain will destroy itself.Sommerfeldt wrote: ↑24 Jan 2019, 00:12 Well... I guess it’s not overkill if you really want to push those quarter mile numbers down...
- S
Sommerfeldt
I mean... just turn the engine sideways (longways?), switch out everything inside the block with new stuff, replace the drivetrain, make it rear wheel drive, replace everything outside the block, put a semi truck turbo on it, swap out the ECU...
The block's good, though. So... good news for OP!
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
We all knew the 2.3 blocks could hold some serious power, but this is on the high end of the spectrum!
precopster
- Year and Model: Lots
- Been thanked: 128 times
The best bang for the buck is what I did to my 2001 V70 T5; a 2001-2002 LPT 2.4l engine mated with bigger T5 turbo and the T5 ECU is a perfect low budget power boost. Perhaps an engine from a 2003-2006 XC90 or 2003-2007 XC70?? The later engines have exhaust and intake VVT which can be left alone in your case. Just time them to the furthest clockwise point upon timing belt fitment. To avoid wear in the VVTs you could open them up and have an engineer weld the internals. This would prevent end-play and oil leaks.
In your case just put in a T5 turbo with associated plumbing (best to remove the engine for this) and T5 ECU for the engine.
The high compression engine from your XC (9 to 1 as opposed to 8.5 to 1) will give great bottom end and a good top end on premium fuel without detonation. Being a 1998 model you'll have zero problems with matching the engine computer to the car (unlike the 1999 and up models)
This combo will have more power than a 1998 V70R AWD due the the engine being higher compression and it will be noticeably smoother due to being from a later generation if you get one of the later engines.
Everything will be stock so part replacement will be a breeze.
I haven't seen any transmission kits that stop the Aisin auto transmissions from self-imploding whether they are the 4 or 5 speed. Manual transmission is the key here.
