White/Blue Smoke from the Tail Pipe 97 R Wagon
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
That should be fine, but you'll be smoking both white and blue if the two top hoses on the oil trap are switched around.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
A little confused here. The port you open up on the PTC is on the base of it, not where the hose clamps.Jhagins1 wrote: 19 Feb 2019, 09:09 TCV has been drilled as big as it can be to still give the hose clamp something to clamp to.
- Chuck W
This is what you opened up, correct?
Reys
- Year and Model: 850T estate '96
I don't think the PTC mod has much positive effect as claimed (my opinion). By drilling the bottom larger only when the throttle is open will it help a little. When idling that hole being larger hurts the system, as the throttle is shut the small vacumm line that is attached to the PTC will have a harder time clearing the gases from the larger PTC hose when it's able to pull air more easily from the bottom of the PTC opening. What is beneficial and was later done by Volvo is adding a quality one way valve along the small vacumm line going to the PTC, having it orientated so it can pull vac and crankcase gases but block off the flow of positive air from going back through the PTC and into the turbo when on boost. Makes sense? Better clearing of the crankcase when under throttle, plus no boost leak which is what happens without that check valve
Jhagins1
- Year and Model: 97 855R
Sorry took so long to get back to you all and thanks for all the help. That is not the port that we drilled. We drilled the port with the small hose going in which I am sure ruined the valve. Ugh. I will source a new intake tube and will put the in line check valve that was suggested. As far as the turbo, it is dry no oil leaks. This is another link for the one I bought if you all think I should change back to stock I am completely down with it just want you all to look at what I got and see if this all could be self inflicted. https://www.ebay.com/itm/Turbo-FOR-Volv ... Sw29JcJenu
Last one more mention here is that there is oil pushing out from the oil cap. I forgot to mention this before but thought it might be something to mention in all of this.
- 1776 Views
Last post by erikv11
- 12 Replies
- 959 Views
Last post by xHeart
- 2064 Views
Last post by RickHaleParker
- 1825 Views
Last post by volvolugnut
- 1184 Views
Last post by FireFox31
