Lower control arm and CV boot, should I bother?
Boot Rip During Control Arm Swap
- Been thanked: 504 times
FYI,vtl wrote: 20 May 2019, 13:21 Yes, Castrol HD does not have MOS2 as it seems, good to go. MOS2 kills the tripod joints.
MOS2 does not kill CV joint. Do a little google search "MOS2 CV Grease" and you will see MOS2 is in the CV grease for many cars.
- Has thanked: 311 times
- Been thanked: 817 times
You think the raxles item was bad, or you think it was expensive? Huge difference. Marty and raxles.com have a universally stellar reputation, this would be the first time I've heard of a problem with them. What was the problem?vtl wrote: 16 May 2019, 17:54 ... I think one of the most expensive ($200ish) was Raxles, and it was not good.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Had to unpack my mail archive to find out the details. I must apology, I've never had a Raxles axle (got a reply that they don't rebuild Volvo axles). About 5 years ago I was going through miserably experience of passenger side axle replacement with aftermarket, cheapest was like $90, the most expensive is in $200 range. Ended up buying an original axle.erikv11 wrote: 21 May 2019, 12:28You think the raxles item was bad, or you think it was expensive? Huge difference. Marty and raxles.com have a universally stellar reputation, this would be the first time I've heard of a problem with them. What was the problem?vtl wrote: 16 May 2019, 17:54 ... I think one of the most expensive ($200ish) was Raxles, and it was not good.
I'm sorry about Raxles confusion, memory starts to lie
- June
- Has thanked: 523 times
- Been thanked: 261 times
Where did you get a original axle for $200? Junevtl wrote: 21 May 2019, 12:43Had to unpack my mail archive to find out the details. I must apology, I've never had a Raxles axle (got a reply that they don't rebuild Volvo axles). About 5 years ago I was going through miserably experience of passenger side axle replacement with aftermarket, cheapest was like $90, the most expensive is in $200 range. Ended up buying an original axle.erikv11 wrote: 21 May 2019, 12:28You think the raxles item was bad, or you think it was expensive? Huge difference. Marty and raxles.com have a universally stellar reputation, this would be the first time I've heard of a problem with them. What was the problem?vtl wrote: 16 May 2019, 17:54 ... I think one of the most expensive ($200ish) was Raxles, and it was not good.
I'm sorry about Raxles confusion, memory starts to lie![]()
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Does the ATF sump need to be drained when replacing the seals? Should I pull the seals with a universal seal puller or use the tip of a pry bar?
Got the 4 boot kits and 2 seals for the front axles delivered today. I'll rebuild them within the next 2 weeks.
vtl
No, but 2-4 oz will leak out.
Use 2 seals, one may not hold for long if the original seal started to leak. Just push the first one as deep as you can and then install the other one.
XC70Rider
Original seals aren't leaking yet. Should I push in the originals and follow with the new matching Corteco seals?vtl wrote: 21 May 2019, 18:22 No, but 2-4 oz will leak out.
Using the new Corteco seals I'll search for a socket or pipe to push them in. The right seal is twice the size of left seal.
