Volvo 850 strange boost problem
projectsmorol
- Year and Model: 2008 c30
Waste gate and/or hoses.
2008 C30:
Darton wet sleeves|CP Carrillo pistons&rods|Upgraded injectors|K16 turbo|3"downpipe|ELEVATE:cat back|custom intake|turbo intercooler hard pipe|lower motor mount|turbo blanket|intake plenum|downpipe wrap|dual bypass valve|lowering springs|rear camber arms|do88 FMIC|Porche 70mm TB|BMC air filter|MAF upgrade|Turbosmart waste gate|meth injection|IPD brake lines|NGK iridium 1 step colder|APR head studs|AEM AFR/Boost Gauge|Hilton Tuning
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
Happy to hear you fixed it. What I also found that vacuum hose length to the TCV can magnify such issues. If you keep them as short as possible the boost regulation will respond much faster, also allowing you to set a higher pretension on the Wastegate.Jaumme wrote: 26 Jul 2019, 19:20 Today I replaced the tcv, I installed a newer model (pierburg), the boost is no more spiking it keeps stable but I still see It a bit lowish, tomorrow will install a boost gauge and see how much it's really boosting.
How much psi should a t5 boost in normal conditions?
850 T5-R '95 auto
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
That is valuable Information. Thankshausmeister wrote: 29 Jul 2019, 03:14 If you keep them as short as possible the boost regulation will respond much faster, also allowing you to set a higher pretension on the Wastegate.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
