Volvo 850 strange boost problem
Jaumme
- Year and Model: Volvo 850 T5 1993
- Has thanked: 1 time
- Been thanked: 2 times
My '93 volvo 850 t5 is doing some weird things when i go full throttle, it boost ok till 3/4 of the white lane on the boost gauge and then the boost comes down to the half of the white lane till 5000 rpm, at 5k rpm it goes like 3/4 again, is that normal? or what i shoud look for? the car seems to pull ok but when it reach 5k rpm you can feel it pulling more till 5500.
Jaumme
i tested all i know the tcv is ok and the bypass valve is ok, the wastegate actuator is also ok, all teh vacuum tubes are perfect, there are no leaks in the intake, fuel pressure regulator and pump hold the correct pressure( its new) and everything seems to be ok so i dont know what to look for. The car has 75k kilometers,
- Has thanked: 2857 times
- Been thanked: 1332 times
It could be a collapsing hose. What's the condition of these? Also, on my 850 T5, the large hose on the intake manifold would slip off its mounting point to the manifold.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
i have a similar condition on my 94 T5 M. I got used to it since I couldn't find the source...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Jaumme
LOL i noticed now the volbo and pronlem in the tittle lmao i was too assleep yesterday.
Ok getting in the topic again i recorded a video for you to see the problem.
maybe the tps has something to do here?
- Has thanked: 311 times
- Been thanked: 817 times
That does look like a dead spot in the sensor. However I understood there are two "right" ways to test the TPS:
(1) ignition on, back probe the connector, test voltage
(2) remove TPS, connect to the TPS leads, test resistance
Looks like you are doing ignition on, back probe, test resistance. What are the voltage numbers in the setup you have, does it also peak and drop (presumably), or rise steadily?
viewtopic.php?t=47868
According to the link I posted, you need to use the center pin and one of the outside pins, not pins 1 and 3.
