Engine Oil recommendation ?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Rattnalle wrote: 21 Jul 2019, 04:48
abscate wrote: 21 Jul 2019, 03:53 Harsh winters down there in Jacksonville. Sometimes , June puts a sweater in the car in case she gets delayed.
That's a sure indication you need to use the Russian engine heater.
Lighting a bonfire under the oil pan.
Only if a insurance check is desired! June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June
Post by June »
Rattnalle wrote: 21 Jul 2019, 03:37
June wrote: 20 Jul 2019, 19:41
abscate wrote: 20 Jul 2019, 18:06
June passed him 5 minutes in...
5 minutes?!!! I'm sure I could pass a Mercedes faster than that LOL. Unless I'm driving the C70 2.5T as it's surprisingly slow and the transmission likely would loose its cool! :wink:
Seriously 10W30 is the heaviest grade I would use. Since I switched to Redline 100% Synthetic oil I use 5W30 without issue year round. I still run the Hell out of my T6 even at 185K there is no end in sight for my engine. It runs flawlessly with tons of power and no oil consumption. June
Both grades you list have the same grade at running temperature. They're only different when cold. So 5w40 is actually heavier when running but the same when cold as your 5w30. The winter grade is only really relevant in actual winter when it's freezing.
I'm going to go out on a limb and guess the 10W30 over 5W30 above 86° recommendation has more to do with the degradation leading up to 7,500 miles oci rather than fresh from the bottle protection. June
My Volvo cars owned
1996 960 ordered
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
Well, as this is a first DIY change for me.
I ended up at IPD store and they recommended the "Total Quartz Future 7000 XT semi-synthetic 10w30 engine oil"
Them mentioning the 5w-30 full synthetic wouldn't make much difference and that im good with the 10w30 semi blend....
so i got the kit and changing this weekend.
https://www.ipdusa.com/products/12046/1 ... kit-125520
cbpitt01
Year and Model: 2006 V70 2.5T
Has thanked: 6 times
Been thanked: 4 times
Post by cbpitt01 »
I bought my V70 used, with 183,500 miles, in December 2015. Records showed that Valvoline semi-synthetic had only ever been used. The seller told me it used about 1 quart of oil every 1500-2000 miles. At the first oil change the week after I got the car, I used a can of Liqui-Moly Pro-Line Engine Flush, and then with the new oil I added Liqui-Moly Motor Oil Saver and Liqui-Moly Ceratec. I use Mobil 1 0w-40, which is all I ever used in my prior car from 2001-2015 (158,000 miles), a VW Golf TDi that I purchased new, and it never used any oil between changes every 5000 miles. During that first oil change with the additives, during 5000 miles, I added 1-1/2 quarts of oil. 40,000 miles later, I’m adding 1 quart during that 5000 mile interval, down significantly from the 2.5-3 quarts the prior owner was adding. The Liqui-Moly additives may have made a big difference, but I’m crediting the Mobil 1 0w-40 too.
Through September 30 2019, you can go online to mobiloil.com and click on promotions to get a rebate on Mobil 1 oil. Walmart has the 5-quart jugs currently priced at $22.88 plus tax, and the rebate per jug is $12 (limit 4). I purchased 4 at $97.92 including 7% tax, and less the $48 rebate, my cost was $49.92, which works out to $2.50 per quart - less than most conventional oils! At 6 quarts per oil change, I’ve got enough for 15,000 miles, plus a couple quarts to use to add when needed.
2006 V70 2.5T, Ice White with Arena/Oak, bought “newsed” @ 183,500 miles in Dec 2015; 244,000+ as of 12/23/2020.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
cbpitt01 wrote: 24 Jul 2019, 23:04 but I’m crediting the Mobil 1 0w-40 too.
If you stop using the additive you'll hear that engine groan/moan very deeply (not happy) when pushed hard and oil consumption will go up. Earlier this year I purchased 3 cases at 6 quart each after giving up on Mobil 1 years ago. The 0-40W would provide a year round grade for NC and at Costco prices it was too enticing to pass up. Went back to Rotella T6 and the engines are quieter smoother and not complaining when pushed. The additive is what's keeping everything in check.
Mobil 1 Full Synthetic Motor Oil 0W-40
Online Price 38.69
Less 10.00
Your Price 28.69
Shipping use to be free. Warehouse prices may vary
https://www.costco.com/Mobil-1-Full-Syn ... 69676.html
Try the Rotella T6 next time.
https://www.amazon.com/Shell-Rotella-Sy ... 672&sr=8-4
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Post by reverend »
Yikes, 3 pages in this thread.
Always Synthetic. I use the Mobil 1 10/30 as it's ACEA B1 (or B3, don't recall) that my 2006 turbo requires.
I get it from Costco when it's on sale (usually $10 off) and couple it with the Mobil rebate (usually $12/case), so each case of 6 quarts is $14. Because my car is a turbo, I hesitate to change the oil less than ever 12K miles, and it doesn't use any unless I flog it and am on the turbo more than usual. I only have 165K miles on it.
Edited for clarification on rebate/sale price.
cbpitt01
Post by cbpitt01 »
But Costco doesn’t accept coupons. Maybe you mean you couple it with rebates when Mobil is running a promotion? 🤔
reverend
Post by reverend »
Sorry, I meant the Costco coupon. They frequently (a couple of times/year) have $10 off a case.
cbpitt01 wrote: 31 Jul 2019, 13:16 But Costco doesn’t accept coupons. Maybe you mean you couple it with rebates when Mobil is running a promotion? 🤔
MoVolvos
Post by MoVolvos »
reverend wrote: 31 Jul 2019, 11:16 Yikes, 3 pages in this thread.
I get it from Costco when it's on sale and couple it with coupons, so each case of 6 quarts is $14. Because my car is a turbo, I hesitate to change the oil less than ever 12K miles, and it doesn't use any unless I flog it and am on the turbo more than usual. I only have 165K miles on it.
Was $10 Off recently so around $29 a case. Was free shipping not too long ago also. Same price as Costco Warehouse without shipping price of course. Never seen or been at $14 a case.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Every second Saturday of the month, if you come to NAPA early in the morning (I think before ? 9AM), then you can buy up to $100 with 30% off.
So, I will get either:
1. NAPA synthetic 5W30 or 10W30: normal price $25/5qt x 70% = $17.50...or
2. Liqui Moly 5W40: normal price $38/5qt x 70% = $26.60
