release cv joint Topic is solved
Has thanked: 292 times
Been thanked: 765 times
Re: release cv joint
Post by erikv11 »
That looks like the wrong size clamp. I put them on like in your bottom pic, and just have to struggle a little to get them hooked before finishing with the pliers clamp.
What part number boot kit did you get?
This is for a non-turbo 850 correct?
Was it easy to get the boot on?
Sometimes you will find a turbo axle has been put in a non-turbo car. Turbo axle is larger diameter and takes a different boot.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
vovo850
Year and Model: 1995 850 glt
Has thanked: 49 times
Post by vovo850 »
Correct non-turbo 850 glt.
Boot was fairly easy to get on, little tight on the smaller end but I expected that.
Not too difficult to get the larger side on, mostly just dealing with slippery rubber.
I didn't have to pry with anything to get it to suck up onto it.
Here is the link to what I bought. https://www.fcpeuro.com/products/volvo- ... o-31256235
part# 300427 #97 stamped on the clamp if that helps any
1995 Volvo 850 GLT N/A automatic wagon
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
vovo850 wrote: https://www.fcpeuro.com/products/volvo- ... o-31256235
part# 300427 #97 stamped on the clamp if that helps any...=
PN is correct from GKN. Clamp is the wrong size.
See if FCP can send you another kit (GKN does not sell the Oetiker clamp separately).
The CV Boot kit is only $9.50.
vovo850
Post by vovo850 »
cn90 wrote: 03 Nov 2019, 21:59
I bought 2 of the kits, they both have the same size clamp.
Now I didn't stick the other one on, I just eyeballed it. It looked the same. (same stamping)
I thought maybe I bought the wrong kit, since I bought them separately.
Checked the other box, same part#, same clamp.
I think I am going to contact them and see whats going on though.
I need new clamps one way or another.
Post by erikv11 »
Actually I am pretty sure you have the right size clamp, 97 Oetiker is correct for the non-turbo outer CV. And since the boot went on OK, it sounds like it is still a non-turbo CV joint, the smaller one.
Wipe everything clean of grease and you should be able to put it on using the technique in the bottom pic. Make sure the clamp is over the groove in the CV when you go to hook it, sometimes you have to use a needle nose pliers or something to get it hooked. And/or squeeze the clamp all the way around. You probably need to get that grease out of there to get some purchase.
'06 S60 R, 197k
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Small screwdriver through square hole in clamp and tip against hook to lever into place.
vovo850
Post by vovo850 »
So I've been really busy with work and finally tried to do this today..
There is no way that clamp with work, it needs stretched another inch give or take. It won't even fit over the metal part of the joint with it hooked together. Let alone fit over the boot. So I definitely need a larger clamp.
What size clamp does the Turbos use? I went to the parts store locally and tried to see if a Dorman clamp that is about 3" wide would work and it's a tad small still.
Quick look on fcp doesn't appear they sell clamps individually? Maybe I didn't search properly.
Has anyone used the smooth band worm gear style clamps? I was thinking that would be easier to source and make work.
Not sure about balance issues if that is a concern even.
vovo850
Post by vovo850 »
fcp is going to ship me a new boot kit for the turbo for free to see if the clamp will fit.
A1 service and they really didn't have to.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Just replaced a cv boot today on the 98 S70 GLT. Used the Volvo kit which had Ford grease in the box go figure. Used two screw drivers to force the clamp together then used a similar oetiker tool to pinch. Don't forget to burp any air out of boot before you pinch by sliding a screwdriver under the edge of boot.
vovo850
Post by vovo850 »
new boot arrived today, and the turbo clamp fits perfectly, I haven't cinched it down yet but it's obvious it is the correct one.
I'm kind of curious about this axle.
Can you put a turbo CV joint on a N/A axle will it fit?
I'm wondering if that was why I had so much issues with getting it off and back on.
I probably will send back my other boot kit and exchange it for the Turbo one for my passenger side.
My luck will be it will be the correct axle and than I have an axle out while I exchange parts again..
